Old 06-05-2011, 09:24 AM   #1
c-dub
Drives: 2008 yaris
Please help with Rattle coming from cam cover?
Doing the oil on my girls 08 5spd and noticed a rattle coming from the engine bay while parked at idle in neutral. It comes an goes, nothing constant about it. Best guess is its coming from the cam cover and sounds kind of like a pot of boiling water with a lid on it kind of rattle (best I can describe) doesn’t sound like a lifter, or a lower bearing, but I’m not up on my Toyota tech. any ideas that can point me in the right direction?
c-dub is offline   Reply With Quote
Old 06-05-2011, 10:01 AM   #2
Could be the heat shield between the exhaust manifold and the firewall. Or, it's just our normal valve tapping.
Old 06-05-2011, 06:20 PM   #3
c-dub
Drives: 2008 yaris
yah i thought it might be the heat shield, but it looks good and tight. pulled the plastic cover and it sound like its in the drive train on the driver side. dont sound like a normal valve tap, but who knows with 73,000 miles. realy dont want it going to the dealer.
Old 08-06-2011, 11:28 AM   #4
c-dub
Drives: 2008 yaris
got around to taking a closer look today. Pulled the accessory belt off and the noise went away. Put it back on and it was back. Pulled out a stethoscope and tried to listen for anything out of the ordinary on the a/c, alt and water pump. Think I can hear the noise coming from the water pump. Every thing else sounded normal, but I can hear the rattle when I put the scope on the water pump near the pulley just not as loud. Any ideas?
Old 08-06-2011, 09:08 PM   #5
c-dub
Drives: 2008 yaris
how about a faulty Timing chain tensioner? would having the belt on cause extra strain on the chain causing it to rattle? i would think the noise would get worse when you loaded the rpms if it was in the timing gear set?
Old 08-07-2011, 08:03 AM   #6
c-dub
Drives: 2008 yaris
found this on youtube...
http://www.youtube.com/watch?v=M_ggV2MSxTM
...sounds just like that.
Old 08-07-2011, 09:30 AM   #7
bronsin
bronsin's Avatar
With the belt off grab the wp pulley and try to move it side to side. If it moves theres the trouble. Shake the alt and ac pullys too.
Old 08-07-2011, 02:01 PM   #8
c-dub
Drives: 2008 yaris
i did this, but realy didn't notice any movement. maybe a little like a 1/16" or so, but after i pulled the water pump and spun it and than the new one it was night and day.
Old 08-07-2011, 04:39 PM   #9
bronsin
bronsin's Avatar
ANY play side to side and the component is toast!
Old 08-07-2011, 09:33 PM   #10
c-dub
Drives: 2008 yaris
it was plain as day with the new one and the old one side by side.
JUN Releases Camshafts for the 1NZ-FE changchewsoon Performance Modifications 53 01-23-2017 08:28 PM
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 03:30 PM
Weird rattle coming from teh egg. Impresive-G DIY / Maintenance / Service 14 11-10-2008 03:22 AM
