Old 06-08-2011, 08:41 PM   #1
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
2011 autocross goodness (east coast)
I finally got a decent set of tires , Hankook z214 c71 . They really put my nt01's to shame. Now that I compete in SCCA events I was at a disadvantage running 100 treadwear tires in smf. Hankooks seem to be the answer for those who don't want to break the bank with Hoosiers.
Here is recent results from a NASA autocross , I squeezed 9th overall against some very hardcore front runners with dedicated track / autocross machines . I really need an LSD still, but other than that the xa is dialed in.
http://www.get-fast.net/nasacross/052911res_raw.htm
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 06-09-2011, 10:35 AM   #2
Great results! I'm sure a lot of people were saying "um.... what just happened?"
post your suspension set up?
Old 06-09-2011, 12:06 PM   #3
Jason@SportsCar
All that power and an open diff. I bet you could pick up a second with an LSD. I am sure Garm can set you up with a nice OS Giken unit, you wont be disappointed.
Old 06-09-2011, 06:53 PM   #4
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Yea I forgot to say that I run wastegate boost pressure when I autocross . Puts me about 170whp which is plenty for autocross, just enough power to where 2nd gear hooks up without burning tires . Kind of a flip because I usually leave it on high boost driving ... get to the race and lower it haha.
will post suspension later.
Ptuning.com
Old 06-09-2011, 09:45 PM   #5
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
suspension setup ...
Progress coilovers 450lb front springs, 200 rear
Tokico HP rear shocks
front sway deleted
Progress rear sway
949 racing 6ul wheels 15x8
Ptuning.com
Old 06-10-2011, 11:59 AM   #6
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
Your car reminds me of this:
Old 06-10-2011, 03:36 AM   #7
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
if u dont mind me asking. what offset are u running with 15x8?
Old 06-10-2011, 11:41 PM   #8
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I believe they are 35 or 36 offset, I also run 20mm front wheel spacers and 10mm rear hub spacers.
Ptuning.com
Old 06-12-2011, 11:09 AM   #9
MonstarYaris
Drives: 2008 Yaris
Ive see your car all the time when I go to Ptunning. Nice setup and car.
MonstarYaris is offline   Reply With Quote
Old 06-12-2011, 09:22 PM   #10
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Thanks!
Ok so I did another autocross today, I never felt that I nailed a run. I had a hard time getting the coarse down as it seemed choppy to me. And the design today made me realise I probably am giving away a lot running open diff. Off camber turns and uphill start... no good. There were about 250 racers too, so 4 runs was it ( Im used to NASA's 7 runs).
There were things I did, and didn't like about how SCCA does things. But Im gonna do several more during this summer, then Ill judge.
Ptuning.com
8.9 Earthquake off the coast of JDM land ..ie Tsunami! rningonfumes Off-topic / Other Cars / Everything else Discussions 28 03-25-2011 09:59 PM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
West Coast vs. East Coast cali yaris NY / NJ/ CT / PA 22 07-20-2009 11:04 PM
