Old 06-24-2011, 07:55 PM   #1
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
greddy turbo kit
who all is running this kit?
so now we have had this kit for a while, it seems like this turbo just runs out of potential at 4500rpm... leave 1500 rpm of suck!.
ive been looking around and i have found people recommending a td04 hybrid.
funny thing is i have a td04 on my shelf.. then i found this!
http://cgi.ebay.ca/Turbo-CHRA-Upgrad...item415aa6ef79
keeps the same turbine housing but center cartridge and comp housing is changed.
any thoughts? and i plan on doing a full port of the turbine housing to improve the flow rate at higher rpm as well.
Old 06-24-2011, 08:28 PM   #2
are you tuned?
Old 06-25-2011, 01:37 AM   #3
Scubaru Steve
Awesome!
are you tuned?
haltech sprint 500 is on the way, no piggy back can tame this echo.
it seem like its standalone or nothing.... unless there is an fic pro in alberta.
Old 06-26-2011, 10:51 PM   #4
johnny_vitz
Drives: 2005 Toyota Echo
are you tuned?
Is it? Emanage blue is working well for me
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 06-27-2011, 11:00 AM   #5
but didnt you say the tune from greddy left a lot on the table...?
Old 06-28-2011, 06:43 PM   #6
johnny_vitz
The base map from Greddy was awful, that's why I was wondering if he had it properly tuned. It works awesome now, no bog anywhere and it pulls hard all the time
Old 06-24-2011, 10:51 PM   #7
Go for it! Then report!
Old 06-25-2011, 03:32 AM   #8
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Has it always done this or is this a new problem recently?
In other words, did it spool up sooner then 4500 rmp's before?
Old 06-25-2011, 10:57 PM   #9
Scubaru Steve
Awesome!
5psi at 2-2200rpm. you can feel it running out of breath at higher rpm, and no, it has always been like that. we have a 2.25 straight through exhaust. so there is no choking. intake is free flowing as well.
Old 06-27-2011, 05:07 AM   #10
ilikerice
ilikerice's Avatar
yea dude, sounds like you need a turbo upgrade.. I think you have pushed everything that turbo has to offer.
I agree with CaliYaris, get it and report back to us. lol, if you gots the money
Old 06-27-2011, 08:38 PM   #11
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
I got my FIC dialed in great.
pimp my yaris is offline   Reply With Quote
Old 06-27-2011, 09:22 PM   #12
Scubaru Steve
Awesome!
well we have the fic and emanage blue for sale if anyone wants them.
the echo wont leave closed loop untill 5000rpm... its stupid. and still.
we had the fic tuned great. but it only works 50% of the time. this echo is just taking us for a ride, so go standalone and no more fighting with the factory ecu.
im thinking that this compressor upgrade still wont help top end, and looking at the dimensions. i dont think it will even clear the valve cover.
so im thinking i need to buy a microimage manifold, turbo and dp and start over.... sigh* anyone want to buy a greddy turbo kit? its sad becuase 5psi is had right at 2000 rpm....
Old 06-27-2011, 11:17 PM   #13
Focus_Sh1ft
Focus_Sh1ft's Avatar
Uh... Why don't you just turn up the boost if you're concerned with making more power? That compressor housing still isn't a bad idea though.
I really don't think it's worth wasting money on a standalone unless you have substantial boost (10+psi) and even possibly a built engine / cams / head. You can get the FIC "working" 100% of the time by just tuning in open loop bro.
Old 06-27-2011, 11:40 PM   #14
Scubaru Steve
Awesome!
larger compressor housing will help, but with that added air going through, there is more air that needs to go through the already too small turbine housing. that make the exhaust very restrictive and limits power. you can run 20psi, but the restriction from the exhaust will make the added boost pressure useless.
as i said before the car doesnt go into open loop untill 5000rpm at times and full boost is had before 2500rpm, we could force open loop but that isnt what we want for a daily driver. i have been thinking a lot about this project.
Old 06-28-2011, 12:38 AM   #15
Focus_Sh1ft
There's no reason why you can't open up the exhaust more. What's the downpipe / rest of the exhaust diameter?
I think it goes without saying you want the turbine a/r to be as small as possible though to get those ridiculous 2k rpm spool up times. However, you say you want more power in the top end, then state it's for a daily driver. You can somewhat have both, but which is more important to you?
As for the forced open loop tuning I can't stress enough how easy it is to deal with. I only have to make a couple tweaks when the weather gets substantially colder / hotter. Since I've already made a winter map and now am running a summer map, I shouldn't even need to do any tweaking next season.
Oh and also:
spark is getting blown out at higher RPM.
If you have this problem you'll know it lol. At least I did. You can feel the "hesitation."
Old 06-29-2011, 12:19 AM   #16
Scubaru Steve
Awesome!
cast greddy manifold, dp is a belmouth cast 2-21/4, the rest is 2 1/4, 2 resinators and a straight through dynomax.
need the top end because of the automatic, it sucks so bad when you stand on it, car downshifts and its not even in its power band. id rather it spool at 3k rpm and have the power up top.
any tips on forcing open loop when entering boost? coolant temp wont work as car is set to shift at 4k rpm if its cold. any ideas would be great.
a 3psi trigger would be sweet.
Old 06-27-2011, 11:45 PM   #17
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Before you get too far, try one thing for me. (Something I wanted to try myself but forgot to before taking everything off...) Unplug the VVT-i solenoid and give it a go again. I was also going to close the gap on the plugs a bit thinking maybe the spark is getting blown out at higher RPM.
Old 06-28-2011, 12:42 AM   #18
Scubaru Steve
Awesome!
i shall do that, the one thing i did notice, since the car is not tuned, i have the wastegate lock wired 100% open. and as we get to 5000 rpm we hit 5psi.
FS: OEM Toyota Vios Turbo Kit CTScott Items for Sale by private party 24 07-31-2011 09:12 AM
FS: Greddy Turbo Kit Bluevitz-rs Items for Sale by private party 12 09-14-2010 05:27 PM
))) bolt on greddy turbo kit ((( aucorium Performance Modifications 5 02-14-2010 03:32 PM
Greddy Turbo Kit Giupo Items for Sale by private party 17 06-16-2009 05:14 PM
