Old 06-28-2011, 12:32 AM   #1
MyYaris(:
Drives: 2009, white, 4dr, cute
My yaris drives to the side very easily
Hi, I'm sorry if there is a topic already about this. It's hard for me to explain but please stick with me and help if you can. I dont know much about cars.
I had my yaris for less than a year and I always noticed that it's hard to drive it centered..... like it goes to the side VERY EASILY??! especially on the highway. I drove my mom honda civic and noticed how more stable it is. I've been on this website, Yarisworld, before I bought my car and I remembered a Topic about this, and something was used to fix this, something put in the car under the hood??????
I looked through pages and can't remember what it was called.
I'm 19 yearold girl and I drive very far to my university and will again this august. I want to get this fixed because I had some close calls.
Also if you have any other advice on how to take care of my car (other than oil changing and tire rotation) like the basics, please do so[:
Other than that I love my yaris(:
Hope you can help! thank you!
MyYaris(: is offline   Reply With Quote
Old 06-28-2011, 12:37 AM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Under the hood.. would be a strut bar. What would work better is a rear (anti-)sway bar.
Old 06-28-2011, 01:33 AM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
I considered "highway wander" such a serious issue with my car that I dreaded driving long distances on the freeways. After some experimentation, I found the single most important factor to correct this problem was finding the correct tyre! To my surprise, I was finally able to completely eliminate highway wander... even at high speed.
Old 07-01-2011, 03:55 PM   #4
SailDesign
Drives: .
And pressure. "White-lining" is less dangerous in cars than mo'bikes, but what a pain. If you'rte constantly rising onto the high spots, reduce the pressure a couple of pounds. Keep playing till it's right.
Old 06-28-2011, 01:33 AM   #5
When was the last time you had an alignment done? If you haven't had one done, I'd get it checked out (the place that rotates your tires probably does alignments).
As for other maintenance, check your coolant level weekly (better if you can daily), and the same with your engine oil level. I'd check the other fluids at least once a month (better if more often). Check how dirty your air filter is, especially if you live in a dusty area. Replace if it's heavily soiled.
Old 06-28-2011, 04:57 AM   #6
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
+1
Also, is this a brand new car? How many miles are on it now? Toyota will do a complimentary free alighnment before it hits 15000 miles if you have an issue. Could also be that a front tire got separated. If you rotate the tires and it goes away, that could be the issue.
hold up. Is it wondering or pulling you left, right or both?
Could also be just the Highway. Road crown can cause this when people drive closer the the left or right of the white lines.
Old 07-06-2011, 12:20 PM   #7
localkineguy
Drives: 2003 Mazda Protege5
+1
localkineguy is offline   Reply With Quote
Old 06-28-2011, 01:50 AM   #8
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
It's common for a tight Toyota suspension to take a few months to break in. Also the tires needs to set a wear pattern so make sure they're at the right pressure. Be patient and you'll get the stability at high speed.
Read your manual. It will tell you what you need to know.
Old 06-28-2011, 10:13 AM   #9
DMZ
DMZ's Avatar
Drives: 2007 Yaris LB
Take it to the dealer or a tire shop and have the pressure checked, the balance checked, on the tires on the side it pulls to, and the alignment checked.
My Yaris is stone stable at highway speeds. I can let go of the wheel and it will track straight for some distance before small road imperfections cause it to wonder.
It has 50K miles on it and I am running Michelin Harmony tires.
DMZ is offline   Reply With Quote
Old 06-28-2011, 12:58 PM   #10
MyYaris(:
Thank you everyone for the answers and advice!!!!
ilikerice- it's a 2009 with 26000 miles right now & it mostly sways to the right
Old 06-28-2011, 01:28 PM   #11
R2D2
Crazy Oil Sniffer
R2D2's Avatar
If it wanders to the right when on the right side of the road this is normal. It's caused by the crown (curvature) of the road surface, so that water will run off. Depending on the steepness of the crown it can be barely noticeable to dramatic.
Otherwise there is good advice above.
R2
-The Fitful One
Old 06-28-2011, 02:17 PM   #12
ilikerice
ilikerice's Avatar
If you know someone who is mechanicly knowledgeable and you can flirt with or better yet is into you, I'd ask him to swap rotate the tires from front to back.
If it goes away, you probably need new tires cuz one of the fronts tires (now on the back) have separated.
If it still does the same thing, Id look into getting an alignment check.
Anything can make the alignment off, by simple pothole or a curb check may throw it off.
Also: You can try to swap the two front tires left to right. See if it pulls Left instead of Right. That would Definitly confirm a tire issue
Old 06-28-2011, 02:50 PM   #13
MadMax
MadMax's Avatar
Also understand it is a very light car with a short wheelbase, so it will be "twitchier" at speeds and under moderate crosswinds. Please do get it checked out to ensure there is nothing out of order on the car, but it may just come down to the fact that you are new to the Yaris and not familiar with how it handles...
Good luck! M2
Old 06-30-2011, 11:52 PM   #14
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
Good luck! M2
I truly believe this is probably 75% of the reason why this happens with our Yaris... hell, I couldn't even park straight when I first got my hatchback, lol (rear wider than front).
-toy
Old 06-30-2011, 10:31 PM   #15
NZ-FE Vios
Only Timing Chains
Drives: 09YarisSedan, 94Truck22re
I felt a huge difference in the wandering from wind gust or semi-trucks after adding the trd rear (anti)sway bar. It also increased overall highway stability. I've put 4000miles on mine in less than 45days. Most of my driving is highway.
I agree with proper tires, alignment, and equal inflation too.
It will always feel like a 2300lb car, but that's the fun in it.
NZ-FE Vios is offline   Reply With Quote
Old 07-01-2011, 03:33 PM   #16
MUSKOKA800
MUSKOKA800's Avatar
Adding the rear anti-sway bar game my sedan much more highway cross-wind, truck-wake stability. Frankly, it was a handful at highway speeds on a gusty day. No issues now although the 215 tires do have a mind of there own when in the ruts.
Old 07-01-2011, 08:29 PM   #17
sickpuppy1
Drives: 2010 Yaris Sedan
Also note that all cars with factory alignment will pull to the right "slightly" when new. But only if you let go of the wheel. It is supposed to. If you fall asleep at the wheel, the car should pull to the right to guide it that way versus into oncoming traffic. This is mandated by law. That being said, the alignment specs do not have this built in, so when it is realigned, it should go away. I know several guys who get a brand new car realigned shortly after buying them, for this very reason. Its weird though, cause its so slight it doesn't even cause uneven tire wear.Never did figure how they do that.
Old 07-01-2011, 09:11 PM   #18
ilikerice
ilikerice's Avatar
^ Thats probably why they offer first alignment before 15k free. But you have to ask for it though.
Side Airbags Yaris 2007 narkeeso DIY / Maintenance / Service 0 07-20-2010 02:15 PM
WTB: Front, Back, and Side Lip from yaris type-S Vinsanity Willing to Buy by private party 1 12-13-2008 09:58 PM
