Old 07-01-2011, 07:53 AM   #1
ecc_33
ecc_33's Avatar
Drives: 2008 toyota yaris
vs
This is my oil report. I have 60,300 miles on my yaris and use 5w-30 castrol edge full synthetic. Figured some would like to see this. I went about 10,100 miles on the oil
Can a mod edit the title to oil report or something similar. I don't know what happened there
08 toyota yaris with some big tires lol
02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile
ecc_33 is offline   Reply With Quote
Old 07-01-2011, 06:01 PM   #2
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Nice report! I have a couple of questions/comments.
questions:
1. Is this FST (with Titanium) Edge or the original SM recipe? ( OOps, missed that Ti is 0 so this is the original, API SM Edge.)
2. What were you using for an air filter during this interval?
Comments:
The oil "sheared" to a 20wt, a product mostly of the fuel dilution. Blackstone uses a less sensitive "open cup" flash point to calculate fuel dilution so your oil contains much more fuel than shown here. (This is not a slam on the fine folks at Blackstone, it's just the nature of the method.) Using more precise methods such a gas chromatography (GC) I would bet you'd be showing between 1.5-2% fuel dilution.
Wear metals look very good for the interval. I would not stretch the drain interval any longer. 10k mi, max so you have some headroom left. Good show for the Edge. I have the FST Edge in my car right now. I also have some of this SM rated Edge in my stash as well.
-The Fitful One
Old 07-01-2011, 06:11 PM   #3
ecc_33
ecc_33's Avatar
questions:
1. Is this FST (with Titanium) Edge or the original SM recipe?This is the original SM but i have FST in the car now!
2. What were you using for an air filter during this interval?KN air filter
Comments:
Cool! good to know, Thanks!
Old 07-04-2011, 03:45 PM   #4
R2D2
Crazy Oil Sniffer
R2D2's Avatar
BTW, this is COMPLETELY off topic but do you have any pics/video/info to share on your D-Max because that is a pretty impressive quarter time there!
R2
-The Fitful One
Old 07-04-2011, 07:38 PM   #5
ecc_33
ecc_33's Avatar
R2
yes i do! I used to pull it mainly. I only have drag raced a few times. Im second truck in this vid. about 23 seconds in
http://www.youtube.com/watch?v=mRd3k7gQod4
im first truck in this vid
http://www.youtube.com/watch?v=NTs9ok6BfhU
I won this night
http://www.youtube.com/watch?v=CUJV_JzuWHs
This is the only drag racing footage i have of my truck. Im at 1:33 into the vid.
http://www.youtube.com/watch?v=kDdDbtXB8Vo
That was many moons ago when i had a gt4088r turbo and a single injection pump. Since then i have added a second injection pump, nitrous, water/meth injection, and a S475 turbo. I made 3 passes this year before blowing it up. Best to date was the 11.93 pass. Im in the process of building a engine and I took the 4.56 gears out and installed the 3.73's back in. I hope to run at least one low 11 second pass by next fall
Old 07-04-2011, 06:23 PM   #6
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Originally Posted by ecc_33 View Post
Attachment 42685 This is my oil report. I have 60,300 miles on my yaris and use 5w-30 castrol edge full synthetic. Figured some would like to see this. I went about 10,100 miles on the oil
After reading the report and seeing everything is just fine at 10K miles what is your opinion of those that feel a necessity of changing their oil at 3K intervals? Particularily when the lab suggests =
Try 12K miles on the oil next
Old 07-04-2011, 07:19 PM   #7
ecc_33
ecc_33's Avatar
i would say regular oil go no less than 5 thousand miles. I work for columbus airport and we have extended our milage on our vehicles to 5 thousand and everything is still ok. That is with regular oil. I change my synthetic at 10,000 miles cause thats when i do tire rotation and everything. Just makes it easier for me to remember too.
Old 07-05-2011, 05:43 AM   #8
bankrobber
Drives: 2007 Yaris Hatchback
What oil filter did you use?
bankrobber is offline   Reply With Quote
Old 07-05-2011, 12:08 PM   #9
Hershey
Thanks for the report . Very impressive . Iron looks a bit high . Cylinder walls ? . Seems to be the trend with these motors . For comparison to our U.O.A.s go here . http://www.yarisworld.com/forums/showthread.php?t=34042 . Analysis for '08 sedan is on page 2 .
Old 07-05-2011, 08:25 PM   #10
ecc_33
ecc_33's Avatar
napa
Old 07-05-2011, 08:24 PM   #11
craigq
Drives: '07 Yaris, '12 GLI
Thanks for the UOA!
You might want to edit out the personal information from it
craigq is offline   Reply With Quote
Old 07-06-2011, 01:03 AM   #12
kurisu
Drives: 2009 Yaris
Originally Posted by craigq View Post
Thanks for the UOA!
but he needs to take out off his attachment lol.
kurisu is offline   Reply With Quote
Old 07-06-2011, 05:08 PM   #13
ecc_33
ecc_33's Avatar
thanks
