Old 08-09-2011, 07:25 PM   #1
romram
Drives: yaris hatchback
The Vanishing Coins ...
What a good Toyota design!! Well, I place some coins in the center console - drivers pocket of my new yaris. Viola!! It fall beneath the console.... now my problem, how to get those coins??? Any idea? Suggestion?
romram is offline   Reply With Quote
Old 08-09-2011, 07:49 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
were they collectors?
Old 08-09-2011, 08:16 PM   #3
romram
yap. put some coins, then when you try to get them, they slide underneath... can't find where they fell.... i hate coins under the dashboard assembly.... now, how can i remove them, to avoid possible damage to shifter/electrical area?....
Old 08-09-2011, 08:41 PM   #4
You just need to remove the center console to get them. Unscrew the shift knob, remove the screw from the cup holder and pop the center console up. It's like a piggy bank - You collect the coins in there until you really need them, then you take it apart.
Old 08-09-2011, 09:20 PM   #5
romram
Thanks alot! BTW, any pictures what screws to remove(step by step)? it's a auto trans... i just want to be really careful, it a new car, don't want to crack those brittle plastics....or plugs/trims. Are there DIY topic re: disassembly of these , so I would just like to refer to them?
Old 08-14-2011, 11:14 AM   #6
romram
ok, i'll try to remove the center console. i will remove the screw from the cup holder & unscrew the shift knob. so what's next? are there other clips/screws?
Old 08-09-2011, 09:05 PM   #7
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
lol, i have this problem also.. went to grab a couple quarters, got my finger on them to slide upward and then all of a sudden they were gone... I was like "WTF?" haha.. scott is right though. follow his directions
Old 08-09-2011, 10:12 PM   #8
Take a look at the "interior" section of the service manual
http://www.etimago.com/yaris/repairmanual/
Old 08-09-2011, 11:05 PM   #9
romram
thank you for the references.
are these coins will fall just on top of the carpet under the center console or will slip right under the carpet( w/c will be more difficult to retreived)?
Old 08-10-2011, 06:21 AM   #10
if you're unlucky they might slip under the carpet... but it's not too hard to peel away from the center console, if I recall there's a velcro strip holding both sides together up front, open that and just peel the carpet back...
Old 08-10-2011, 01:38 PM   #11
pj. olsson
Drives: Toyota Yaris TS 5 Door
I have the same problem, but be lucky when you get it any time!!!
pj. olsson is offline   Reply With Quote
Old 08-10-2011, 04:41 PM   #12
fnkngrv
fnkngrv's Avatar
it is awesome cause the Yaris LB is like a mobile couch...lol
Old 08-10-2011, 06:26 PM   #13
auxmike
auxmike's Avatar
There's coin slots in the driver's glove box in the HB's.
Old 08-11-2011, 07:57 PM   #14
yaris2010RS
yaris2010RS's Avatar
i had all my coins organized in there untill the first corner...... stupid design
Old 08-14-2011, 02:27 PM   #15
that should be it, just lift from the back and pull the whole thing over the shifter :)
YOu might also want to remove the piece in front of the handbrake with the AUX port (you should be able to unclip the cables from the back to remove it completely)
Old 08-29-2011, 09:05 PM   #16
romram
wow, i tried to remove the whole console, but it's harder than I think! i was not able to remove the clip of the cables for AUX & power lock.
tried to see the coins from the front side of the carpet..it's to complicated.
i'll will try it again next time....
Old 08-30-2011, 01:56 PM   #17
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
You might also want to remove the piece in front of the handbrake with the AUX port (you should be able to unclip the cables from the back to remove it completely)
You really don't have to remove the wiring clips. Just take the whole piece off and leave it there. Take it off by hooking a finger under the hand brake handle where it goes over the plastic flat area that the switches are mounted, and lift it straight up. Pop! it comes off, and you can turn and angle the whole plate assy to lift the console part out without disconnecting any of the associated switch wiring. Much faster/easier than mucking around with the wiring. Less chance for mis-wiring when reassembling. It will be easier to remove the plate when the hand brake is in a lifted/applied position. You can see the outline of the switch plate, and the part that sticks in the little "slot" just below the hand brake handle (when the e-brake is not applied) is where you will lift up. It will take you less time to remove it than reading this!
bobolinko is offline   Reply With Quote
Old 09-18-2011, 12:31 PM   #18
araine
Finally, a Toyota!
Drives: 2009 Toyota Yaris, Base Model
Send a message via AIM to araine
Note to self: When I pick up my yaris on Wed, do not put coins in it....lol
2009 Yaris, Base Model
9-17-2011 at 16K Miles
araine is offline   Reply With Quote
Lost coins... in console?? xmun General Yaris / Vitz Discussion 14 11-07-2010 01:13 AM
Lost coins through centre control panel Former_Neon General Yaris / Vitz Discussion 9 10-14-2009 01:38 AM
