Old 09-12-2011, 11:29 PM   #1
Larapiemort
Drives: 2008 yaris LB
Battery color indicator
I have a 2008 Yaris LB. This morning I was surprised to have a dead battery. I jumped it and after work went to auto one to have it tested. They said it was charged 96% but a bad battery. I didn't buy a new one because I wanted my father to take a look at it. The battery color indicator was blue with a red center. This ment it was good. But I noticed that there was a groove to twist it out. When I did this it was clear with a red center. This ment it was needing to be replaced. But in the tunnel I pulled it from had blue liquid in there. So, which do I go by? Is it still good? I bought an at home charger, was this a waste of time and money??
Help! :*(
Larapiemort is offline   Reply With Quote
Old 09-13-2011, 10:43 AM   #2
barryware
If the battery tested bad, replace the battery. The "eye" of the battery really can not be trusted. It is reporting the condition of only one cell.
barryware is offline   Reply With Quote
Old 09-14-2011, 07:52 AM   #3
Vinceb
Drives: 2008 5 Speed Sedan
Don't believe everything you hear. Canadian Tire tested my battery and said it was "bad" and wouldn't even hold a charge. I took it home put it back in the car, jumped it, let it run for 10 min, drove the car for 10 min and that was about 6 months ago or more. Mine died because I left the lights on. The battery testers don't always give accurate results, and the people operating them aren't always the smartest. looking at mine it's blue with a red dot in the center.
Vinceb is offline   Reply With Quote
Old 09-13-2011, 11:11 AM   #4
ajmarshall169
ajmarshall169's Avatar
Drives: 2007 toyota yaris sports
i would change the battery. you dont want to chance it going dead. i changed my battery 6 months after i took it off the lot just bc i wanted a good reliable battery.
ajmarshall169 is offline   Reply With Quote
Old 09-14-2011, 11:58 AM   #5
Lil Abner
Drives: 2009 3dr LB Manual
That "blue with red dot" is useless. My Celica battery showed that "perfect condition" on the color, but the battery WAS shot.
battery, color indicator
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 03:40 PM
Toyota Yaris Battery Light On - Repair gabo General Yaris / Vitz Discussion 1 08-24-2011 08:21 AM
Charging voltage for stock battery Vinceb DIY / Maintenance / Service 3 02-12-2011 01:10 AM
Installation of a Battery Isolator frostbitten In Car Entertainment + Electronics (audio / video / alarm) 3 10-07-2009 01:11 PM
