![]() ![]() ![]() ![]() Drives: 2013 Yaris Join Date: Oct 2011
Clutch adjustment?
been looking the car over for a while, trying to figure out how to adjust my clutch properly for what I need. I have to floor the clutch for it to shift or i will grind gears, which is not ideal for me, I'm used to my rx7 where at about 3/4 pedal it was open enough. under the hood i don't see if it's possible, and behind the pedal I cant tell if that adjusts out anymore (or at all). where would I look to do so?
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Sep 2010
If it's like the echo, it's not adjustable (iirc) Maybe your rx7 uses a clutch cable instead of hydraulic? You may just have to get used to it :(
05' Echo Hatch - Greddy Supercharger - rear disc |
nah, the RX7 was hydraulic but it was perfect for me. I'll give it another look see, and if it's not adjustable i'll have to figure something out, like a rubber boot or something i can attach to the pedal give it just a little more movement.
It's not adjustable. Lifting from the floor, when does it engage exactly?
There are aftermarket clutches that release the plate higher up on the pedal -- it's an expensive mod just for that, though.
Micro Image forums, online store and shop are now closed. It was a great eight year run, but it was time to focus on other things. I'm still selling parts on eBay under micro*image seller ID and customers can still make requests for anything specific. Last edited by cali yaris; 11-21-2011 at 11:47 AM. |
dang, that's nothing i like to hear, I'll have to figure out the point that it starts to engage, don't know off the top of my head.
it's just an annoyance, mostly. if i wouldn't rest my left foot on the dead pedal area i wouldn't have the problem, seems i touch that area with the left of my foot sometimes and it causes me to think i have the clutch depressed completely. |
engages about an inch from the floor. guess I'll just deal with it :x
2ZR swap. DO IT! Ask how!
It could also be your footwear: I have problems in the winter with my heavy boots, but not in the summer with running shoes. Here's one possible solution.
makes it a tad easier knowing there's a write up and it's been done before, lol. I was thinking about removing that entirely and mounting a metal dead pedal too.... I have the easiest time driving in my converse, so i've been wearing them most the time. i can drive in my boots but it gets a little difficult at times :p
This is annoying for me too. My shoes are size 12, and I did the "big foot mod" already, which helps. But still, it's hard to press the clutch pedal all the way down when I'm wearing shoes with rigid soles. About 10% if the time, it grinds as I try to shift with the clutch partially engaged. To avoid this problem, I usually drive barefoot.
#10 | |
| HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. | trini_per4mance | DIY / Maintenance / Service | 42 | 03-27-2017 03:59 AM |
| Clutch shudder when setting off in 1st gear | BuildCode | DIY / Maintenance / Service | 87 | 06-17-2015 07:14 AM |
| clutch adjustment | 1krzys | DIY / Maintenance / Service | 0 | 09-01-2011 03:10 AM |
| Help Me Find The Right Clutch | RacerFreakXXX | Performance Modifications | 18 | 10-20-2010 05:20 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 11:34 AM |
