![]() Drives: Toyota Vitz (Yaris) Join Date: Nov 2011
Toyota yaris OEM Speedometer + Tachometer HELP!!!!!!!!!!!!!
Guys i bought a Toyota Yaris (vitz) 1.0. The car cluster has only speedmeter no tacho. I want to ask that if i buy original cluster wth speedometer and tachometer would it will work with the same wiring. i have seen that both meters have same harness slot.
PLz help!!!!! |
To be sure, check the smaller of the two connectors on your car. Pin 15 should be a black wire, between a violet wire with a white stripe and a yellow wire. If that black wire is present in pin 15, then the wiring is in place to allow the tach to work.
@. Ctscott I want to ask that when I start the car ABS light does not pop up unlike all other lights such airbag pop up and go away. Plz help what's the matter
There are clusters for cars with and without ABS. Sounds like you got one for a car without.
That means that my car is without ABS :( ????
![]() ![]() ![]() Drives: 2007 Yaris Sedan Join Date: Apr 2009
Did the original cluster have a ABS Light that went On?
If the original one did light and the one you now have does not. You most likely got one that does not support ABS. |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| FS: CA 2009 Toyota Yaris OEM MP3 CD Player | weedtank | Items for Sale by private party | 0 | 09-28-2011 05:59 PM |
