Old 12-08-2011, 12:02 PM   #1
StrangeRanger
Drives: none yet
Steering effort/feel
I am seriously considering buying a 2012 Yaris 3 door L.
The very few things that I don't like about it are easily fixed except..
the power assisted steering has way too much assist and way too little feel for my taste. Is there any way of reducing the assist and hopefully increasing the feel?
StrangeRanger is offline   Reply With Quote
Old 12-08-2011, 12:08 PM   #2
Buy a SE or pull the fuse and go totally manual. Been talked about quite a bit, but nobody has successfully implemented variable assist.
Old 12-08-2011, 12:35 PM   #3
StrangeRanger
Drives: none yet
The SE doesn't come as a 3-door and it comes with too much in the way of "features" that I dislike. The chief appeals of the L are the lack of rear doors and its stripped down content.
Totally manual doesn't bother me in the slightest. I really don't see why a 2200# car even needs power assist. I have driven many in that weight range that were not assisted and had no issues.
If you pull the fuse, are you still fighting against the electrical assist, increasing the effort sort of like a hydraulic assist with a bypassed pulley? Or does the electrical system just go into neutral?
Is the assist from an SE retro-fittable to an L? That might be the easiest although certainly not the least expensive fix. The boneyards aren't exactly full of Yaris SEs
Old 12-10-2011, 10:17 PM   #4
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
you can always swap in the se steering rack! that's gives you the quicker ratios and better feel, and you could probably keep the same power assist as the base.
Old 12-08-2011, 03:47 PM   #5
Captain Slow
My Face Is Ridiculous
Captain Slow's Avatar
Drives: 2010 Toyota Yaris 3dr LB
i guess because I'm used to twitchy front ends on my RWD drive cars I rather like the the strong assist on the power steering in the Yaris. makes it feel like I can chuck it into a corner.
of course it's all personal preference though, many people in the Miata world disliked power steering, they said it was twitchy, I liked it twitchy.
Captain Slow is offline   Reply With Quote
Old 12-08-2011, 05:03 PM   #6
There is almost zero assist over 50 mph. The steering ECU reduces control as the car increases in speed. Remember, this is an electric motor assist, no hydraulics on the Yaris.
With that said, mine's deleted. I like it better without.
Old 12-08-2011, 09:04 PM   #7
Viperoni
Drives: 2005 Toyota Echo
bigger rims and shorter profile tires.
2006 Saturn Ion Redline
Old 12-09-2011, 12:19 AM   #8
^ for a harsher, slower ride.
Old 12-09-2011, 01:14 AM   #9
Captain Slow
a valid point, if you can't stand driving it then it doesn't matter how the steering feels ;)
Old 12-10-2011, 12:43 AM   #10
Viperoni
I shoulda clarified 205/50/15's or similar ;)
Old 12-09-2011, 02:53 AM   #11
CanIHazYarisHatch?
Drives: 2012 Yaris 3-door w/5-speed!
I'm right there with you.
My one, and only complaint, about the 2012's.
CanIHazYarisHatch? is offline   Reply With Quote
Old 12-09-2011, 05:56 AM   #12
http://www.autospeed.com.au/A_111532/cms/article.html
A little technical, but this guide lets you use a potentiometer knob to fine tune the overall level of assistance :)
The problem with simply removing the fuse is that your arms will get the additional resistance from the inoperative gearing and motor...
Old 12-09-2011, 11:19 AM   #13
Captain Slow
awesome link!
that will be a "must do" item on my list eventually. I love uber-nerdy mods like that. thanks.
Old 12-09-2011, 11:29 AM   #14
StrangeRanger
Drives: none yet
That link looks like it may prove to be the solution.
It certainly will provide an improvement and the cost is near zero.
Many, many thanks. This makes the purchase decision much easier
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Is this normal with the Yaris steering lock? STC General Yaris / Vitz Discussion 13 07-06-2010 10:15 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
Steering Wheel Spacers? BassAssassin Cosmetic Modifications (Exterior/Interior) 0 08-12-2009 12:52 PM
