![]() Drives: 2009 Yaris Join Date: Sep 2011
Not so hidden yaris sub install - advice on the rest of the system?
So after Christmas came and went I decided to buy myself a JL 12w3 and a JL JX1000.1 amp to go along with it! Before this i had just done some modest work on the car including deadening the doors, spare tire compartment, and rear side panels as well as adding a fosgate r150-2 that runs my polk db651's in the door. The "problem" I've run in to is that the bass now far surpasses everything else in the system, to the point that even when fully turned down to -5 on the HU the front polks can barely keep up. I was thinking of upgrading the fronts to JL C3-650's, getting a JX360/2 amp for them and then moving the polk setup to the back. Would this be sufficient to kind of even things out? I'll start actually taking pictures of my installs, especially now that I'll probably be deadening the hatch and couple other problem areas & then doing a component install.
Thanks! Here is the sub install: ![]()
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
uh... you have un-amped speakers and amped 12"? Yeah....mismatch.
I've got a 10" R, and it deafens everything else when turned +5, but is nicely matched with 0 or +2. That's with the front and rear amp'd 75W each (PDX5). |
the fronts are 2 amp'd polk db651's with the rockford r150-2, sorry for the confusion :x
I would set up "gains" on the amps first.
D.
. CLA 250, 4MATIC |
| 2012 Camry | Kal-El | Off-topic / Other Cars / Everything else Discussions | 26 | 10-02-2011 09:20 PM |
| Consumer Reports Is On Crack!!! | doublewam | General Yaris / Vitz Discussion | 82 | 05-07-2011 11:03 AM |
