Old 01-03-2012, 02:17 PM   #1
Arkhangel
Arkhangel's Avatar
Drives: 2007 Yaris Sedan
Shocks/Struts suggestions
Looking for new Shocks/struts suggestions, i got TRD Springs and thinking about KYB GR2 ...
Yes... No?? Better Options?? Need it to be affordable.
The difference between fiction and reality? Fiction has to make sense. --Tom Clancy
Arkhangel is offline   Reply With Quote
Old 01-03-2012, 02:21 PM   #2
coilovers or bust
Old 01-04-2012, 01:44 AM   #3
Viperoni
Drives: 2005 Toyota Echo
Koni Yellows.
Next best thing to coilovers, for the most part.
2006 Saturn Ion Redline
Old 01-04-2012, 10:35 AM   #4
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
I don't think Koni is currently making the Yellow Sports for the Yaris just yet, at least they don't have a part number available in the catalog.
Gr2 shocks work best with stock springs.
If your looking for affordable go with tokico blues with trd springs it will be as good as you can get for under $500 unless bilstein starts making options available to us.
A year ago vogtland used to make a spring/shock combo that used decent springs with bilstein shocks for $5~~ but it looks like that is no longer available.
Old 01-04-2012, 11:44 AM   #5
^ Correct.
No Koni yellows for us.
GR2 is a very slight upgrade from stock.
Tokico red > Tokico blue > TRD > GR2 > stock
Old 01-04-2012, 02:50 PM   #6
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
^ Correct.
I've got the Tokico Blues (Tokico HP). Not a hard-core shock, but better than stock and very reasonably priced (especially from Micro Image!).
Old 01-04-2012, 03:00 PM   #7
MUSKOKA800
MUSKOKA800's Avatar
I'm thrilled with my TRD Spring and Damper set-up however I'm sure the Tokico Blues would work nicely. In fact, if I need to replace mine I'd likely give the less expensive Blues a try. They were not available when I did my upgrades.
FYI: my TRD dampers are a product of KYB. No doubt the same housings as the GR-2 but with more aggressive valving/damping rates.
Old 01-04-2012, 07:39 PM   #8
^ same with my TRD dampers.
and +1 with Garm's ranking.
Suggestions for Tool Bags fnkngrv DIY / Maintenance / Service 11 10-18-2011 05:29 PM
Whats Next? Suggestions Please :0 Nips General Yaris / Vitz Discussion 13 08-15-2011 05:29 PM
Front strut replacement/ suggestions jstantherprsn DIY / Maintenance / Service 4 04-28-2011 03:39 AM
I lost my master keyless entry key, need suggestions.... Frankd1 DIY / Maintenance / Service 19 12-01-2010 11:13 PM
Suggestions for new tires DJPaneno Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 05-06-2009 11:16 PM
