![]() ![]() Drives: 08 BMW 135i Join Date: Jul 2011
Same size wheel, different offset.
Guys, thinking of ordering these for the Yaris:
http://www.tirerack.com/wheels/Wheel...7&autoModClar= Problem is, Tire Rack says two offsets fit, both +42 and +38. Which ones should I order? I plan on getting 215s put on them and the car will be lowered slightly. Thanks. |
やりすぎだ~
The difference is a few millimeters. The +42 wheel will sit slightly farther inside the wheel well compared to the +38 wheel. I would go with +42 to be safe.
20lbs. is heavy wheel, but seems to be the going weight for cast 17" wheels. |
I had a set of 16" ASA AR1's on my car with 45's up front and 38's in the rear.
If you don't want to stagger offsets, I would definitely go with 42's. |
These are my first option, not sure I want to spend this much though:
http://www.tirerack.com/wheels/Wheel...7&autoModClar= |
| Bolt Pattern Size and Offset for the Stock Wheels | fmicle | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 08-12-2009 03:35 PM |
| Which wheel size with DF210īs? | Danish Yaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 02-03-2009 01:28 PM |
| Whats the highest offset and tire size for 17s you could go... | YarisSedan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 12-15-2008 09:40 AM |
| Wheel offset questions.. | Jerkratt | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 11-04-2008 01:32 AM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
