Old 02-08-2012, 02:25 PM   #1
scene
Drives: 2010 Toyota Yaris 1.5L, 4D
new brakes or some bs upsell?
i went to get some maintenance done and the people said that I needed new brakes, it is common for this car to need new brakes? It's a 2010 yaris (auto) with only 16000 miles on it! When I bought this car it already had 5,000 something miles on it.
I might go to the dealer or another shop later on this week to get a second opinion but I am kind of surprised since i thought brakes were supposed to last at least 25,000 to 30,000 miles. I don't drive with both feet ("riding the brakes") and I mostly use it to commute about 7-10 miles (14-20 miles total) each day. Mostly highway too, maybe like 1-2 miles is driven in the city.
scene is offline   Reply With Quote
Old 02-08-2012, 02:27 PM   #2
Gotta be BS. Factory brakes should get you 60k plus.
Old 02-08-2012, 02:48 PM   #3
scene
60k! Wow is that how much you drove before you replaced them or just a consensus?
In the off chance that I do need new brakes, do you think that Toyota would honor their warranty to replace the brakes? Given the high discrepancy between the consensus and my situation, it would be logical to say that new brakes would be covered by Toyota.
Old 02-12-2012, 12:09 PM   #4
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Drives: 2013 Yaris 5 dr liftback
You have to take into account individual driving. Almost all my miles are interstate and I have over 60k and my front pads and rear shoes are nowhere close to being replaced.
Get a second opinion. It is possible that you have some problem that is causing the excessive break wear....or maybe you drive with you foot on th brake all the time which causes quick wear out.
Get a 2nd opinion!
Big Dave
Indianapolis, IN
Synthetic Oil....its in my car.....for at least 10,000 miles!
daf62757 is offline   Reply With Quote
Old 02-08-2012, 03:02 PM   #5
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
how much brakes was left?
new one are usually 10mm thick
if they were between 1-2 mm then yupper they ready to change
OTA'sTOY is offline   Reply With Quote
Old 02-08-2012, 03:10 PM   #6
scene
he didn't say, just said I needed new brakes
Old 02-08-2012, 03:20 PM   #7
bronsin
bronsin's Avatar
The odds are you are dealing with a total scumbag. My wife couldnt wear out a set of front brake pads that fast.
Old 02-08-2012, 03:27 PM   #8
scene
yea it was sort of weird, the guy that was doing the oil change and inspections didn't say anything (maybe he forgot to inspect the brakes?) and was really helpful but then out of nowhere a second guy comes in and tells me I need new brakes. FISHY and left me almost speechless since I have such a low amount of mileage to need such a major level of work done.
thanks yarisworld for your input! I will take my car to the dealership some time next week (or month) since it doesn't seem to be a pressing issue to confirm the diagnosis or lacktherof.
Old 02-08-2012, 03:38 PM   #9
I have 25K on my 2009 and a couple of weekends ago, while I had it up on the lift with the tires off, I checked my brake pads and they had barely any wear at all.
Old 02-08-2012, 05:25 PM   #10
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
This. Mine's 2008 roughly the same mileage, and brakes look like new. It might be slightly different with an auto as mine is manual and I tend to downshift and only use the brakes to come to a complete stop.
Unless the previous owner stood on those brakes 24x7 I doubt they need replacing. I think the worst case I ever read about on here was at 15K but the driver admitted to being a brake abuser.
Old 02-08-2012, 03:44 PM   #11
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i got 91000 km on it on the original brake pads just hitting half not even..i can probably do 3 more years..it is a manual ..
Old 02-08-2012, 05:25 PM   #12
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
manuals use infinitely less pad than autos. I went for a drive the other day and I could touch my rotors- they weren't even hot
Old 02-08-2012, 05:55 PM   #13
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
mine is a 2010 also, i got 28k miles on my car. still have at least 50% on my factory pads..
oh did i mention I autocross once a month since I got it?
-Derrick-
Old 02-08-2012, 06:28 PM   #14
yaris2010RS
yaris2010RS's Avatar
2010 with 60000km and rear pads have 3mm left
Old 02-11-2012, 01:22 PM   #15
scene
went to toyota to check the brakes and they are at 8mm front, 5 mm rear
lol @ some people!
Old 02-12-2012, 01:29 PM   #16
^ read this post!
lol @ some people!
Old 02-11-2012, 05:20 PM   #17
bronsin
bronsin's Avatar
Just a heads up about the dealers. They can be crooks too! An honest one is a godsend.My daughters 98 Camry was making a lot of noise. The exhaust manifold was cracked. She took it to a dealer and was told she needed $3200 of work including water pump, radiator, head gasket (as well as the manifold.
My brother in law did the work for $800.
Old 02-11-2012, 06:53 PM   #18
scene
since the yaris is front wheel drive how come the brakes in the rear are more worn down than the front? Are the rear brakes less thick than the front? yea i was really skeptical of taking my car to the dealership at first but my dealership is really good at taking care of their customers except for that fact they can get really busy (1-2 hour expected wait for simple jobs!).
When I was in an accident a few years ago with another car, we got a quote from them as a baseline and used that to compare with other shops. The quote we got from toyota matched the shops in my area with the exception of a couple of shops beating toyota by margins.
general service of brakes TriumphAnt DIY / Maintenance / Service 10 08-07-2010 02:20 PM
Rear Drum brakes bankrobber DIY / Maintenance / Service 0 04-17-2010 11:39 PM
Metal scratching from brakes alt_k1ll3r DIY / Maintenance / Service 16 02-11-2010 12:04 AM
