![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
hid install help (ground)
so i got my ddm tuning HID (slim ballast) there's a positive wire and two negatives. I connected the positive and negative to the battery terminals, and then the other negative i am trying to figure out where to connect. i think it is for ground, i tried tapping to a bolt it works both lights come on but the bolt is so tight it's not possible for me to unscrew it, i don't think it is made for ground. Which bolt is made for ground? right now only 1 side of the hid comes on. thanks!
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
So when you ground this wire your lights work normally? You can turn them on and off?
Not quite a noob
You can really ground it on anything in the engine bay. Find a bolt that you CAN unscrew and use that.
thats the thing.. i can't really unscrew any of the bolts lol... mainly the placement of them are awkward, couldn't get my wrench to work or it's too far in the back couldn't get the leverage, is there anyway i can just stick it on top of the bolt? there are not many bolts honestly i can choose from...:(
![]() ![]() Drives: Gen3 Yaris ZR Manual Join Date: Jan 2012
Connect both negatives together on the battery negative.
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
man their are lots and lots of bolts in the engine bay......
my passanger side ground it on the engine itself if u jsut cant seem to get it there are quite a few GTA members around here im sure some would be willing to meet and help
i'll give the engine a try!
thanks guys, able to unscrew the engine nut, wohoo I'm going out to test my HIDs!
Pirate Yaaaaris
Drives: '00 Toyota Celica GTS 6MT Join Date: Aug 2009
There should be a bolt on the passenger side strut tower behind the headlights that you can use as a chassis ground. That's where mine is. It also holds on my relay box just fine. Sorry it isn't super detailed but I'm at work and just went out and shot it with my phone. Hope this helps.
![]() ![]() -C
Georgia Bulldogs! ![]() '09 Yaris LB 5MT Sold. |
#13 | |
#14 |
Pirate Yaaaaris
Should be two holes. One directly above another. There are matching holes on the strut tower on the driver's side that should have battery/ECU grounds attached to it.
I'm not sure on the size bolt that fits in there, but it seemed to be a common size and should be available at your local Home Depot or equivalent hardware store. I'd feel much better using that location rather than grounding directly on the engine. The engine moves. The strut tower, unless you get in a huge crash, doesn't. -C
#15 | |
#16 |
Pirate Yaaaaris
No problem. If I get a minute tomorrow, I'll see if I can take that bolt out and give you a rough idea of what size you might need to look for.
-C
#17 |
sounds good!
#18 |
does anyone know why my hids will only turn on after a few tries switching the light on?
it always takes the second attempt for the lights to come on |
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 08:47 AM |
| $120 AUS PER KIT XENON XTREME SLIM HID $120 | JDMWAT | Items for Sale by private party | 0 | 03-02-2011 02:27 AM |
| How to choose and install HID on FOG light | charleschia1986 | Cosmetic Modifications (Exterior/Interior) | 18 | 12-20-2010 09:45 PM |
| HID install, High-beam indictor on | kw0n3k | Cosmetic Modifications (Exterior/Interior) | 7 | 07-24-2010 05:48 PM |
| HID Lights Install ? | k3nn4 | Australia | 30 | 02-07-2009 08:42 PM |
