Old 03-01-2012, 09:45 PM   #1
Dave55
Drives: 2008 Black Pearl Yaris
Please confirm this fit (185/60R 15 on 15x6.5 +38mm offset)
I've read all the fitment posts, and all I can about offset. But since I'm very new to all this, there's still a lot of confusion.
Am I correct that 185/60R 15 on 15x6.5 rims with a 38mm offset will fit without any rubbing issues on an unmodified Yaris?
Also, what, if any, change or effect would the change in offset from the original 45mm have on handling?
Found some wheels I like on craigslist and wanted a second opinion before buying.
Thanks
Dave55 is offline   Reply With Quote
Old 03-01-2012, 10:41 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
185/60/15 on 15x6.5, ET45 will be an excellent fitment without any rubbing issues whatsoever.
Old 03-02-2012, 06:32 AM   #3
Dave55
Kimona,
the new rims I'm look at are ET38, not ET45.
will those still fit?
Old 03-02-2012, 03:37 PM   #4
kimona
kimona's Avatar
No problems with this fitment.
Old 03-02-2012, 06:52 AM   #5
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
you should have no problem with that setup at all. BTW 185/60/15 is the stock tire setup so you already know that fits.
Old 03-02-2012, 08:45 AM   #6
Dave55
Exactly. Those tires are currently on the stock rims.
Just want to make sure there would be no problems with a new set of rims with different offsets.
Old 03-02-2012, 10:18 AM   #7
Dave55
Related question,
Other than fit issues, what effect would the change of offset (from 45 to 38) have on ride, handling and such??
Or is it only a fit issue.
Old 03-02-2012, 10:39 AM   #8
1.5
Form>Function
1.5's Avatar
the offset change is going to push the wheel closer to the fender and the outside of the car. This wheel choice is not going to require any modification to work so no negative effects like rubbing should occur. The wider wheel and lower offset is going to widen the stance resulting in improved performance and handling. Hopefully the wheels are lighter than stock also improving performance.
Old 03-03-2012, 06:36 PM   #9
33OH
Drives: '08 Yaris
What he said, 15x6.5 +38 will work perfectly. Btw - welcome, I'm from NEO as well. :)
would 16x8 with +25 offset fit on the rear? marcus Cosmetic Modifications (Exterior/Interior) 15 09-15-2009 03:43 PM
hard to find anything that's NOT 38 or 40 offset... will these fit without rubbing? tonyg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 03-19-2009 08:53 PM
Will a 15x6.5, ET40 with 195/50/15's fit? schleppy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-12-2009 08:30 AM
Offset 42 -> will it fit? Homeboy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 12-24-2008 04:39 AM
