![]() ![]() Drives: 2007 yaris sedan Join Date: Aug 2011
full range class D amps
Are the full range class D amps being made today comparable to the class AB amps to be used in a 4 speaker setup with no subwoofer. Is one more preferable to the other as far as sound quality all specs being equal.
Roadrunner Jr.
To argue with a person who has renounced the use of reason is like administering medicine to the dead. ― Thomas Paine |
which specs are in play after install hu or amps specs. also if the hu and amp are approximately at the same level will one hear the difference in sound iow will the sound get better with the amp install or do you have to get an amp significantly better than the specs of the hu.
Roadrunner Jr.
In a lot of cases, your quality of sound will depend greatly on the quality of your install. Induced RF noise is a big enemy.
| October 16th Sunday 2-6pm, Shannonville Full Track event! 20th event of 2011!!! | Touge.ca | Canada | 2 | 10-06-2011 12:07 AM |
| June 25th Shannonville Full Track lapping event 2011, 5:30-9pm, 8th event of 2011!! | Touge.ca | Canada | 1 | 06-25-2011 02:59 AM |
| June 4th Shannonville Full Track lapping event 2011, 6-9pm, 6th event of 2011!! | Touge.ca | Canada | 0 | 05-20-2011 02:42 AM |
| May 14th Shannonville Full Track lapping event 2011, 6-9pm!! | Touge.ca | Canada | 5 | 05-12-2011 03:23 AM |
| August 28th Shannonville Full Track lapping event! Touge.ca 11th event of 2010! | Touge.ca | Canada | 2 | 08-24-2010 04:25 AM |
