Old 04-08-2012, 09:21 AM   #1
gubloom
Drives: Silver yaris
Will 205/55/15 tires fit on Yaris?
I own a standard yaris with factory shocks and tyres size 185/60/15
Will 205/55/15 fit with no rubbing ?
gubloom is offline   Reply With Quote
Old 04-08-2012, 09:24 AM   #2
If it's not lowered, should be fine. I had 215/35R18 on my old wheels, so diameter was quite a bit larger than stock, and lowered on coilovers, didn't have so much rubbing.
Old 04-08-2012, 09:29 AM   #3
Onads
Onads's Avatar
Drives: Vios/Yaris
Yes it will fit.
Onads is offline   Reply With Quote
Old 04-08-2012, 06:50 PM   #4
gubloom
Thanks everyone does anyone actually have this size on their Yaris is it a nice feel when driving ? As far as I think 195/55/15 would be a the perfect size for a nice feel drive.
Old 04-08-2012, 07:01 PM   #5
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
Another option to split the difference would be the 205/50 size. When you say "nice feel" are you looking for comfort or handling?
Old 04-09-2012, 08:40 AM   #6
gubloom
Well, I drove my friend's Toyota Corolla with tyres size 215/45/17 and then we changed the wheels to 205/55/16. Under normal speeds driving in the city the 205/55/16 felt a much nicer drive. It also seems that if you get wider tyres than stock tyres the steering can become a little heavy.
Old 04-09-2012, 09:45 AM   #7
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
There is more rubber in between the wheel and road. Hence more comfortable less hard ride.
Old 04-08-2012, 06:59 PM   #8
grelise
Drives: 07 YR Yaris 5dr Hatch
You have to make sure the rolling diameter between the stock size and the new size your after is as close to factory as possible.
Go to www.miata.net/garage/tirecalc.html fill in your stock size then the size your after and it will give you the Rolling diameter. You are allowed 15mm either side of the stock size.
grelise is offline   Reply With Quote
Old 04-08-2012, 10:14 PM   #9
kimona
kimona's Avatar
Drives: 2014 White VITZ
205/55/15's will fit nicely.
Tire Size = Diameter
185/60/15 = 23.7
195/60/15 = 24.2
195/55/15 = 23.4
205/55/15 = 23.9
195/50/15 = 22.7
205/50/15 = 23.1
Old 04-09-2012, 08:57 AM   #10
gubloom
In my opinion 195/55/15 will be the most suitable size for a yaris. Any comments regarding this statement ?
Old 04-13-2012, 06:32 PM   #11
gubloom
I have just put 205/55/15 on my 1.5L Yaris with standard manufactorer shocks and springs (not lowered at all). The drive feels hard and not so comfortable. I think this size is an overkill for a small car like a Yaris. I think 195/55/15 is most suitable.
Old 04-13-2012, 07:17 PM   #12
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
which Australian version of the car do you have and what extras did it come with? There seem to be so many different models down under.
Colin Chapman disciple
Old 04-13-2012, 07:21 PM   #13
Blue Beast
Drives: 2010 Yaris 3 door hatchback
I have 205/55/15's on my Yaris with 15 by 7" rims, TRD lowering springs and TRD Sport Shocks and everything is perfect, no rubbing issues and could not be any happier with this set up.
Blue Beast is offline   Reply With Quote
Old 04-13-2012, 08:34 PM   #14
Billiam
Drives: '10 White Yaris 4D LB
TRD Springs, 15x6 rims, +39mm offset, 205/55/15 tires....no rubbing....rides and handles great.
If you want to enjoy your car, stay off of the internet.
Old 04-13-2012, 11:09 PM   #15
rcast2010
Drives: advance 2010, rines 17,
ruedo mucho tengo 205/40R17 suspencion fabrica, poca diferencia en el manejo pero comodo...
rcast2010 is offline   Reply With Quote
Old 04-14-2012, 06:07 PM   #16
gubloom
My Yaris is a 1.5 litre YRS model with no modifications at all. It came with basics wheels size 185/60/15 on simple standard metal rims. The steering was easy and the drive felt good.
I then changed it to 205/55/15, there is no rubbing but the stearing felt heavy and the car felt heavier as well. It seems that the ALLOY rims together with the tyre weight around 15kg where the other wheel with metal rims weights around 8kg. The car feels more stable but overall I think this size is an over kill for a small car like a Yaris. 195/55/15 probably would be most suitable.
Old 04-14-2012, 07:57 PM   #17
why?
why?'s Avatar
Drives: Yaris LB
ah, so you went with aftermarket rims at the same time. Yes wheel and tire weight can make a gigantic difference in how a car feels, especially in a car that is this light and powerless.
Old 04-15-2012, 04:41 PM   #18
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
in general the 15 range will not give you any problems, I have mine lowered 1.8 inches (4.572cm) and have plenty of clearance.
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Why does everyone compare the Yaris vs Fit... b_hickman11 General Yaris / Vitz Discussion 71 03-03-2009 09:57 PM
yaris tires for sale Adriaan Items for Sale by private party 1 08-05-2006 01:22 PM
