![]() Drives: 07 Yaris Sedan Join Date: May 2012
Coilover Install... Problem
Started to put my new megan racing coilovers on today and for the life of me, I could NOT get the 2 bolts that hold the shock to the wheel hub loose. Basically the two bolts that clamp around the shock assembly to hold it in place. Snapped 3 sockets, and broke a wrench trying to break these two bolts loose. Even got out the Sh-long breaker bar... nothing. Question is this, is there a trick to loosening these bolts? Are they left handed threads? thanks ahead of time
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
I had the same issue on mine. Bolts are meant as a permenant bond so they are torqued extremly tight. On top of that they come into contact with all the road dirt and grime and elements.
You didnt list this yet so I will recommend trying some PB blaster or WD40 on them. Spray loads of it on the bolts and try and get between the washer looking part of the bolt and the hub itself and between the nut and the bolt. Let that sit for a while and give it another go. I did this but unfortunately the only thing that worked for me was to find someone to zap it with an impact gun. They were just too stuck to remove with hand tools. GL |
Ah yes I used Liquid Wrench on it, AND then used an impact on the bolt side while my dad used the Sh-long breaker bar on the nut side... no luck... they are standard thread correct? Lefty loosey? lol
Yes, the threads are standard lefty loosey.
How long did you let the Liquid Wrench sit? If they are that difficult, spray it down and let it sit overnight. If they still won't budge, try heating the nuts with a propane torch if you have one.
tighten them a tick with the breaker bar and then try to loosen them
@WeeYari, I soaked the nuts in LW, then changed the oil in my dads car and came back to them. And @sex im going to probably grab my neighbor's gas welder and heat it accordingly
0-60 in slow
Drives: light blue liftback Join Date: Aug 2009
You can always try hitting them with a hammer. If you get a really big iron mallet something in the 5lb range should work, put the wrench on as you would and hit the end of the wrench with the mallet. That should put enough impact on the nut to break it free.
FYI do not heat suspension components with a torch its a really bad idea. Rubber+Heat=Failure |
#8 | |
![]() ![]() ![]() Drives: 2010 Yaris HB Blazin' Blue Join Date: Feb 2011
racerb
racerb '86 Celica GT '87 Celica GT-S '98 Rav4L '01 Tundra SR5 |
not much rust/ice/salt out there in Riverside. It's usually our Northern & Eastern neighbors that have the most trouble. Got air tools?
Form>Function
woah^
So good news is, nuts are off... bad news is I guess I have NO idea on how to get the tophap to sammich between the top. Basically it seems to seat in the upper strut housing, but as soon as i lower the car, the whole assembly pushes up and heads towards the hood... like its not having any pressure between the coil itself and the hole in the engine bay (ie stock tophat mounting possition)
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 08:47 AM |
| Warrany Service Problem? | 2009Yaris | General Yaris / Vitz Discussion | 4 | 03-31-2011 04:56 PM |
| Problem with my car | rakhan01 | DIY / Maintenance / Service | 8 | 12-03-2010 05:12 AM |
| Dealers are refusing to install cruise control | xenu | General Yaris / Vitz Discussion | 12 | 07-17-2010 12:49 AM |
| Megan Coilover install DIY | kapo | DIY / Maintenance / Service | 5 | 09-24-2007 07:20 PM |
