| View Poll Results: Which Rear Swaybar Woould You Buy? | |||
| Ultra Racing 19mm |
2 | 6.25% |
| Ultra Racing 23MM |
20 | 62.50% |
| Whiteline |
10 | 31.25% |
| Voters: 32. You may not vote on this poll | |||
![]() ![]() ![]() Drives: 2010 Yaris HB Blazin' Blue Join Date: Feb 2011
Which Rear Swaybar Would You Choose?
Just to see what the interest level is for options on rear swaybar. Choices being Ultra Racing 19mm, Ultra Racing 23mm, or the newer Whiteline unit.
Let's find out what you guys really want for your Yaris! racerb
racerb '86 Celica GT '87 Celica GT-S '98 Rav4L '01 Tundra SR5 |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
I chose the TRD sway bar because you can't see it...
![]() ![]() It has a couple of extra bends which make it tuck neatly up into the fold of the crossmember so that nothing is hanging down below the chassis. I live in an area where having more ground clearance is good.
jqueza@microimage
Drives: 2010 vios Join Date: Apr 2012
whiteline its ajustable........
![]() Drives: Toyota Yaris Join Date: Oct 2010
I have the TRD and it's good for street and first add on.
And you can Feel a difference. But I would go with 23 mm now for street And adjustable for more serious intentions.
Thomas Paine Stage One Yaris TRDsway bar, TRD springs & shocks, TRD Quick shifter kit, TRD CAI, TRD oil & coolant cap Microimage light crank pulley, Agency Power steel braided brake lines. |
I have the TRD as the rest were not out at the time. It works for me so really no need to change.
While I did not include the TRD bar, that is another option and with the current price Sparks Toyota TRD Parts has it listed for, it's pretty damn reasonable!
http://www.trdsparks.com/displaypart...&parts_id=1374 racerb
![]() ![]() Drives: 2011 yaris Join Date: Mar 2012
I chose trd....not a vote option
2ZR swap. DO IT! Ask how!
I'm pretty sure TRD isn't on the list because the intent of this thread is to show Garm that there is still significant interest in the 23mm UR bar. There was talk of discontinuing the 23mm UR in favor of the adjustable 22mm Whiteline bar.
#9 | |
racerb
play every day
Well us East Coast people think differently, usually don't have to make thing painfully clear to others!! LOL........
racerb
I got the 23mm ur
I wanted the 23mm. Told the four bushing whitehouse was better, I chose to go trd. So...voice of reason having to spell it out for us stupid people, translate trd as a vote with my feet fo the lack of 23mm availability. Doi!
#14 |
What I did was ask if there was interest in the 23mm UR sway bar at the $200 price point. Because that's what it will be if we re-order it. (maybe a little less) --- racerb, pretty sure, said he'd be ok with that pricing level. I have an order pending, but let's see what you guys say in here. (I'll cross post this in your poll thread as well)
If you really want a UR 23mm sway bar right now, they are available on eBay. The reason I'm pushing Whiteline is because they are motivated to work with us, offer great pricing, and there is ZERO downside to their product -- it's simply better! Thanks everyone!
Micro Image forums, online store and shop are now closed. It was a great eight year run, but it was time to focus on other things. I'm still selling parts on eBay under micro*image seller ID and customers can still make requests for anything specific. Last edited by cali yaris; 05-24-2012 at 01:03 PM. |
#15 | |
![]() ![]() Drives: 2012 Yaris L 3Dr Join Date: Aug 2009
Just curious: what do you mean by better? Do you mean less body roll (as in more effective)? or Better quality (have you had issues with the UR)? or do you just mean better customer service? The reason I ask is this: I had a Mazda2 with RacingBeat rear swaybar; it was not exactly the same setup, but was similar in that it had the "U" brackets that mounted over the beam. While it was VERY effective at keeping the car flat in autocross, I found it to be overkill for daily driving: I constantly had a wheel in the air when turning into driveways, and had to retighten the U-bolts several times to keep it tight against the beam. Now it appears that the Whiteline does allow for some twist in the beam, which could help to eliminate the "doglegging" problem, however, I am still concerned about having to continually tighten the U-bolts. Also, have you had any issues with squeaking bushings? Eventually, my urethane bushings began squeaking and required removal/relubricating. While this all may seem like minor maintenance (and it is), and I may seem lazy, its just that I see no need in buying a product that requires this type of maintenance if it is overkill for daily driving / occasional autocross when other options are "install and forget it". Your input is greatly appreciated!
#16 | |
#17 |
FedEx guy just dropped my 23mm UR bar off, hope to get her installed tomorrow and do a little road testing!!
Thanks Garm (Micro Image) racerb
#18 |
Great questions.
When I mean "zero downside", I am including most of your concerns. No reports of noise, doglegging, or properly installed bolts/nuts coming loose from the several sway bars I've sold so far. I can only answer to this point in time, as I don't have a long history with Whiteline. Yet! ![]() I'm going to switch on my own car and give some feedback from the track. I could make some predictions, but I think it's best not to do that. Customer Service: Huge point, glad you brought it up. Problem or flaw with UR bar: it's 100% on me, I can't send it back to Malaysia or get a replacement, etc. I have to be real and start including that in my pricing. Whiteline is here and 100% responsive to us. I can get parts, replacements, etc. and the shipping cost from the Malaysia to the USA doesn't have to be passed on to you guys.
| 2012 Nissan Versa | Kal-El | Off-topic / Other Cars / Everything else Discussions | 22 | 06-15-2012 04:48 PM |
| Removing Rear Seat | bronsin | DIY / Maintenance / Service | 4 | 04-11-2011 02:34 PM |
