Old 05-26-2012, 07:00 PM   #1
skootdog
skootdog's Avatar
Drives: 2011 White A/T
Pulley Squeak
I just put in a new pulley from micro image and now the belt is squeaking against it. Makes my engine sound like Donkey! Solution anyone?
"Because it's Racecar"
skootdog is offline   Reply With Quote
Old 05-26-2012, 08:08 PM   #2
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
did you check and make sure that the alternator was pulled back to it's original position and did you make sure that it is aligned correctly. If it is a little off it could make some noise on when the belt rubs the A/C compressor.
Old 05-26-2012, 08:34 PM   #3
Vioz
Drives: 2008 Yaris Sedan
Send a message via AIM to Vioz
Just take the bar to change your tire with and wedge it between the alternator and mount and pull back on it while tightening the bolt on the alternator to lock it in place, did so with mine and it stopped the squeaking. Also make sure your belt isn't damaged, didn't notice mine was damaged and it completely snapped while I was driving and my engine overheated :)
a.k.a. "Aothachos"
Vioz is offline   Reply With Quote
Old 05-27-2012, 08:39 AM   #4
skootdog
skootdog's Avatar
I had put a mark on the alternator and the bracket before i loosened it to take it off. The belt still looks ok from what i can see. It starts to make it once the engine get warm.
Old 05-27-2012, 10:44 AM   #5
You should re-tension the belt, regardless of where your mark was.
Old 05-27-2012, 01:15 PM   #6
and do not under any circumstances spray anti-squeal in there... I had a squeaking problem too, thought it was already too tight so tried that stuff, and well... belt disintegrated not too long after...
Old 05-27-2012, 06:19 PM   #7
Golddeenoh
Golddeenoh's Avatar
^ well it quit squealing once it wasn't there anymore
Old 05-27-2012, 07:45 PM   #8
skootdog
skootdog's Avatar
Haha. Thats one way to fix it! Ill try tightening a bit more a see. I pulled on it and it seemed really tight, almost to tight if you ask me Thanks!
Old 05-28-2012, 07:25 PM   #9
skootdog
skootdog's Avatar
Ok, so I tightened it. It pulled about a half inch or so but it still squeaking. I dont have any way of checking the tension but i know its snug now. Anymore suggestions? WD40...A new kinda belt, Haha. I think when I get home tomorrow Im going to take it off and have another look.
Old 05-28-2012, 11:46 PM   #10
Was the pulley 100% installed correctly? Torqued to 95 ft/lbs.? Just checking.
Old 05-29-2012, 11:36 PM   #11
skootdog
skootdog's Avatar
Yep, went and bought a torque wrench just for it. I listened today when my lady got home from work. I think it may have stopped. I'll have to get back to it when i can. Thanks
FS: NST 20% Overdrive Alternator Pulley MGargano Items for Sale by private party 12 06-05-2011 11:06 AM
FS: 2009 Alternator & Overdrive Alt. Pulley MGargano Items for Sale by private party 9 10-28-2010 07:42 AM
Gearbox/diff squeak, poor engine braking Kiz DIY / Maintenance / Service 8 08-01-2009 09:35 AM
NST (NonStopTuning) Ebay Feedback & Rating NonStopTuning NonStopTuning 0 07-19-2009 10:11 PM
NEW GROUP BUY: NST WP-Lite & ALT-Lite Pulley Kit (NonStopTuning) NonStopTuning NonStopTuning 266 09-29-2007 02:51 AM
