Old 06-13-2012, 05:36 PM   #1
Rami yaris
Drives: Yaris 2007 1.3
How to replace a broken wheel stud
Am going to explain to you how to replace a broken wheel stud in your Yaris or any car. Reason I wrote this topic is yesterday my car wheel stud brak. So I thought to show how did I replaced it so people can get benefit from this
First: This is the broken stud
[IMG][/IMG]
Second: remove the tire
this is the broken stud after removing the tire
Third: You have to remove the brake drum
you will find 2 holes this can help you if the drum is stuck
you can use bolt into in order to help you removing the drum if stuck
[IMG][/IMG]
This is after removing the drum
Fourth: With a hammer you can hit on the screw that you want to remove
Fifth: instal the new stud
To give you more details how to remove the old stud and instal the new one I will give you this video from youtube showing with details because I didn't show in details removing and instal, that because I didn't have video camera at that time. So you can follow on the video
http://www.youtube.com/watch?v=cSiqDdRejyo
Rami yaris is offline   Reply With Quote
Old 06-13-2012, 06:32 PM   #2
Klink10
Klink10's Avatar
Thanks for the post and link.
Old 06-27-2012, 05:54 AM   #3
yaris4062007
Drives: 07 BB yaris / 06 Mustang Gt
nice job :)
yaris4062007 is offline   Reply With Quote
Old 06-28-2012, 05:34 PM   #4
RedRide
RedRide's Avatar
I once had two rear wheel studs break (drum brakes) at a tire dealer when they removed the wheels to install new tires. This was the very first time any of the wheels were removed.
I actually saw it happen.
The tire dealer told me that it happens more than some people realize and they replaced them for free in a couple of minutes. They obviously had much experience at replacing them.
Old 06-22-2012, 07:31 PM   #5
Nicfin
Nic
Drives: 2008 3-Door Liftback Manual
Good post Rami.
The number one cause of broken wheel studs is due to irresponsible service people using air wrenches set at maximum torque. Some even cross thread the lug nuts on the stud with the air wrench because they were too lazy to hand start it first. Cross threaded or not, the air wrench is screwing it on.
So, when you try to take off the lug nut, the lug will break because it is on so tight.
Anytime I have my tires removed from the dealer, the first thing I do when I get home is to loosen them with my air wrench and tighten them down to around 75 foot lbs.
I recently had new tires and wheels put on my Yaris at the dealership. My air wrench could barely loosen them. If I had a flat tire on the highway, I would have broken off every lug trying to take the tire off.
Nicfin is offline   Reply With Quote
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Wheel Stud specs thetut Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 03-29-2012 03:22 PM
Broken Wheel stud !! vten Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 08-26-2011 10:04 AM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
