Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 06-19-2012, 02:11 AM   #1
BoyMalambing
BoyMalambing's Avatar
Drives: Toyota Echo 2005
205/40/16 to 195/40/16 or 195/45/16
Mga Kabayan,
Konting advice lang po... ano mas maganda kasi eto problem using existing tire spec:
1. sumasayad sa fender yung gulong ko existing pag nabigla sa humps
2. medyo matagtag sa rough road
Any idea sa price kahit china na muna ako... waiting for your inputs/comments
This is my 1st first car in Saudi Arabia
BoyMalambing is offline   Reply With Quote
Old 06-19-2012, 02:26 AM   #2
syntax
syntax's Avatar
as per my previous post pre' manipis ang tirewall expect mo na matagtag yan. as in 40 to 45, 50 t0 55 bearable na yun tagtag, pero naka 16 ka kaya most probable sasayad pa lalo sa fender wall ng echo mo, marresolve lang ung sasayad kapag nabigla sa humps is to get stiffer springs or shocks. or palit kang 15" mags and 55 to 60 tirewall tire specs.
sa price no idea pre
correct me if i'm wrong mga kayaris.... opinion lang po ito at hindi conclusion hehehehe
Old 06-19-2012, 03:51 AM   #3
jonimac
jonimac's Avatar
Send a message via Yahoo to jonimac
@boy, some factors are to be checked, isa na rito yung OFFSET ng rim mo kaya medyo naka labas at na-sayad sa fender. May mga naka setup sa grupo na 205/50/16 pero walang sayad o anuman. Most of them 205/45/16 ang nakalagay at lalong walang problema. Meron pa ngang naka 205/45/R17 wala ring sayad na nabanggit sa amin. If you don't mind kindly check first the offsets of your rims, it should not be less than 38, going below this lalabas ang gulong mo. Minsan din nakaka apekto ang design ng rim, may pasok o labas ang mga LUGNUTS, you will notice nagbabago mga OFFSETS ng rim depende sa mounting nila. Otherwise, go for smaller rims katulad ng nabanggit ni syntax 15" to be safe at all. It's up to you bro, "LOOKS" or COMFORT". Kasi ako balak kong mag 18" (215/35/R18) ....joke! In my dreams!!!
jonimac is offline   Reply With Quote
Old 06-19-2012, 06:24 AM   #4
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
nothing to add tol akala ko 20" ang ilalagay mong rim, diba sabi ni kuya bong pwede un sa yaris pero wala ng goma at sa riles ka ng tren dadaan
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 06-19-2012, 07:03 AM   #5
syntax
syntax's Avatar
oo nga pwede rin mag open wheel well ka, ala F1 race cars hehehehehe
Old 06-19-2012, 12:45 PM   #6
jonimac
jonimac's Avatar
Usapang @#$%^&*! lang yun bro meron naka 20" search nyo rito, possible mga tol! Kidding aside nasa size 18 kasi yung type ko, type lang naman, medyo naghahanap kasi ako nitong mga nakaraang araw nalibot ko na lahat ng tindahan sa ghurabi and mostly CHINA made meron ding mga TAIWAN, merong mga US made pero NO TYPE ang design bukod dun over price! Maybe I wil go for 17" if not 13" hehehe joke! (Paliitan naman tayo) Haaayyyy... kelan kaya?!!! Hopefully may mag SPONSOR!!!
Old 06-19-2012, 01:07 PM   #7
duke_afterdeath
tol 17" pa lang nakikita kong pinakamalaki with 40series na goma, kung 18" rim baka 35 na lang goma mo nun or 30 kaya?
Old 06-19-2012, 01:13 PM   #8
jonimac
jonimac's Avatar
@duke, 215/35/R18 ang exact size. Sa 17" naman, si mike mcdo 45series ang pinalagay nya just to have extra rubber ka nya, no rubbing issues sabi nya,... still OFFSET matters.
Old 11-23-2012, 04:12 AM   #9
blackmamba
CP3
blackmamba's Avatar
Drives: BM - Yaris 2012 Sedan
Kung 205/50/16 wala ba namang sayad kahit loaded yarii natin?
blackmamba is offline   Reply With Quote
Old 06-19-2012, 07:29 AM   #10
BoyMalambing
Siguro rubber damper will help din para di masyado matagtag. wala pa budget para magpalit ng tire and rims...
Old 06-19-2012, 08:11 AM   #11
syntax
syntax's Avatar
sa palagay hindi pa rin masyos ng rubber damper un pre, usually rubber damper is to restrict ang compression ng springs... ( ito nga ba un?) hehehhe parang hindi ata
Old 06-19-2012, 08:39 AM   #12
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
Ako balaha na si batman parang nasira plano ko ng malaman ko na titigas manibela ko pagka nag 16 ako at 205, kaya parang delikado sa rack&pinion ko kasi may nasira na dito sa office niyan kaya alangan ako.
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 06-19-2012, 12:21 PM   #13
jonimac
jonimac's Avatar
@charlie, that is why for "every MOD there's a RISK"Some of them are merely psychological, If I can bear with it why not? Subukan muna kaya natin yung kanila, para may pag basihan tayo, matigas nga ba? o nakaka- aning lang? Paki sagot nga mga naka 16"-17" mags dyan... anyhow that is me, tnx.
Old 06-19-2012, 12:41 PM   #14
duke_afterdeath
hehe tol i think wala sa laki kundi sa lapad ng gulong kaya tumitigas manibela,, iba na kasi ung grip sa road kapag lumalapad mas makapit na,,, yun lang!!!
Old 08-11-2012, 06:31 PM   #15
johnraiden12
Drives: toyota yaris sedan 2007
mas gumanda ang takbo ng yaris ko ng palitan ko ng 205/50/16 un lang ang masasabi ko pro try ko prin palitan ng 205/45/ after .
johnraiden12 is offline   Reply With Quote
Old 06-19-2012, 01:10 PM   #16
duke_afterdeath
tol ito o naka 18" pero hatcback http://www.yarisworld.com/forums/showthread.php?t=38956
Old 06-19-2012, 01:12 PM   #17
duke_afterdeath
parang kalesa na cguro manakbo sa tagtag
Old 06-19-2012, 05:38 PM   #18
charlieXX
Corporate Slave
charlieXX's Avatar
@joni I want to indulge talaga tol and try it more on porma and function + performance na naman for me, kaya well wait lang ng blessing tol pagka dumating
Hankook Ventus HR II 205/40/16 dngz Items for Sale by private party 0 10-06-2006 01:24 AM
