Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
exhaust bracket bolt?
Anyone know the part number to the bolt that goes into the side of the header bracket. it is by where the bottom of the header and the mid-pipe meat. Mine worked it's way out driving through Columbia yesterday and now my car sounds like a go cart or a lawn mower until it warms up good. I would assume that the bolt held the mid-pipe in just the right place to close a small gap.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
goes between/through parts 1 and 3 in this picture
91672-81025
thanks, found a bolt in the garage that works but i'm sure I will need to replace it for the right one sooner or later.
If you found one that fits you are all set.
well when I was putting in the bracket bolt I realized that one of my shiny new stud nuts had backed off and that the real exhaust leak is from there. so now I get to aggravate Garm and order a new stud kit to replace that one nut. :D of course it is the one that was difficult to get to from the top so I will have to get to it from the bottom and make quadruple sure it is tightened down right next time.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| Micro Image Short Shift Kit DIY | jpmck03 | DIY / Maintenance / Service | 17 | 02-24-2014 07:57 AM |
| does BACK-PRESSURE increase MPG vs straight thru... | marcus | Fuel Economy Forum | 25 | 05-03-2009 09:23 PM |
