![]() ![]() ![]() Drives: 2009, auto, 4dr LB Join Date: Nov 2010
My view...............
Friend commented recently on how much he liked how I have setup my"stuff" in my car. Thought I would share it.
This is my view as I drive, GPS (Hardwired) and UltraGuage in glove box behind steering wheel. Wires come out the front of the glove box and chase down the steering column, lid closes, np. Radar Detector mounted on and below rear view mirror (Hardwired). I tucked the RD wire into the headliner only I didn't remove the A pillar air bag cover, the more I read about those clips holding the cover in place the less interested I was in messing with them. There is a "rubber" trim piece that is between the air bag cover and rest of the A pillar that runs all the way down the inside of the forward door jamb. Pulled that out a little bit at a time and chased the RD wire all the way down to the fuse box. GPS and RD are both on Add-A-Fuses 2 or 3 amps ea. *Hat tip to shaggyone at planet-9.com for the radar detector mount idea. http://www.planet-9.com/cayman-boxst...rt-9500ix.html cheers BTW- My view is much clearer than this pic appears to be.................. |
Similar gps setup. Liking it for sure. No radar detector though.
![]() ![]() ![]() ![]() Drives: 2017 Yaris IA, Pulse Red, Auto Join Date: Jun 2010
Congrats re your purchase. I don't know what the OP and others use, but I swear by what are now called Scotch All Weather Fastners (they used to be called 3M Dual Lock Fastners -- same product). package of 4 1"x3" Clear strips (2 sets). I used to get them at Radio Shack, but I don't see them at RadioShack.com. Target has them. Not available online, but in the stores. Their site shows that stores near me have them in stock, so it seems to be a popular item. The 'application example' on the front of the new packaging (the lone example) is an aftermarket GPS monitor mounted on a car dash. They don't lose their adhesive in SE Texas heat. I've been using them for over 10 years and I can't remember any of the strips ever failing.
NICE!
And of course, you have the 5 speed (grinding my teeth ) |
Auto
No kidding, I thought domestic yari that came with a Tach were 5 speeds, maybe that was the LB's
ok, not grinding |
#8 | |
![]() ![]() ![]() ![]() Drives: 09 3dr LB MT Join Date: Aug 2009
2009 3dr LB MT Meteorite Metalic. Car bought 8/7/09. Now over 89k miles of trouble free driving, other than user error!!
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
Possibly. But mine isn't a base model.
![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
i dont like the idea with the cover up though, neat.
Free Mustache Rides
that is a good radar mount idea. i always had that crappy flimsy holder and rested it on top of the mirror. thanks for posting.
#14 |
I gather when imported from Japan, the yaris center cluster was left as is, & they simply just swapped sides for the steering wheel.
#15 |
My 2008 has no tach (stich shift). I added one though.
#16 |
![]() ![]() ![]() Drives: 2010 Prius, 2007 Yaris Sedan Join Date: Oct 2009
I think it's a sedan vs LB thing, not a manual vs auto. Sedan's have tachs.
#17 |
2010+ have tachs, here's my car setup. only a scangauge mounted just behind wheel. I use the radio screen for the gps when mounted with my iphone.
[IMG] [/IMG]
#18 |
Me likes that engine start button^^
Does that work with just a fob in the pocket, a la Prius?
| Temp guage and compass in Rear view mirror | Chaad32 | Cosmetic Modifications (Exterior/Interior) | 10 | 10-30-2020 07:47 PM |
| Heated Side View Mirrors | goku87 | DIY / Maintenance / Service | 27 | 01-26-2016 05:23 AM |
| Rectangle Rear View | dlinkwit27 | Cosmetic Modifications (Exterior/Interior) | 14 | 03-29-2010 11:49 PM |
| The screws underneat the side view mirrors... | Sodium Duck | Cosmetic Modifications (Exterior/Interior) | 16 | 03-25-2009 08:04 AM |
| Reposition rear view mirror? | atebit | Cosmetic Modifications (Exterior/Interior) | 0 | 11-26-2006 07:56 PM |
