Old 08-24-2012, 12:14 AM   #1
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Side Exit Exhaust
I just wanted to share this with the Yaris community as I just finished it up tonight but I've built a side exit exhaust for my Yaris. Yes its loud much louder than you'd imaging a Yaris can be.
Old 08-24-2012, 12:31 AM   #2
hahahahahahahha awesome :D
Old 08-24-2012, 01:15 AM   #3
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
That's really cool, namer...
Can you post a video of your car running?
Old 08-24-2012, 01:16 AM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
NEED SOUND NOW!
Old 08-24-2012, 01:46 AM   #5
Nice, think you're the first to do it
Old 08-24-2012, 01:47 AM   #6
Also I'm assuming you're not running a muffler, just header, cats, and resonator?
Old 08-24-2012, 02:50 AM   #7
xnamerxx
0-60 in slow
xnamerxx's Avatar
This is a full 2.25" mid pipe all the way down. Its got a single cat in the front and a muffler where the resonator used to be but nothing after that.
I took the OBX pipe from Jason and modified it to my needs. This whole setup is quite a bit lighter than the stock exhaust that I removed from the car.
Old 08-24-2012, 03:00 AM   #8
tooter
play every day
tooter's Avatar
Is this setup going to cause you problems passing a smog test?
Old 08-24-2012, 03:11 AM   #9
xnamerxx
0-60 in slow
xnamerxx's Avatar
Probably, although i'm sure it would pass the sniffer I wouldn't dream of driving this exhaust on the street. Side exhausts have a few problems that make them not ideal for driving on the street, one of the biggies is that you have reduced ground clearance so you have to be extra careful over speed bumps and pot holes.
For my needs it works pretty well as this setup will weigh at least 5 lbs less than a similar rear exit exhaust plus I get the move all the muffler weight inboard and in front of the axle. Plus its a side exhaust so its cool
It only takes 15 minutes to swap back to the stock exhaust since its only 4 bolts so its only going to be used for racing events since I'm a bit nervous about the police harassing me if I drove it on the streets.
Old 08-24-2012, 03:03 AM   #10
With one cat gone and no resonator...should sound aggressive
Make sure you get start up and WOT in the video
Old 08-24-2012, 03:12 AM   #11
xnamerxx
0-60 in slow
xnamerxx's Avatar
I'll post a video tomorrow I don't feel like having my neighbors hate me tonight
Old 08-24-2012, 06:51 AM   #12
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Thats similar to what im going to do for my next exhaust...however im going to try to run dual exit
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-24-2012, 07:46 AM   #13
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
Are you gonna do a center exit malibu :D
Interior:ALL red, black roof
Old 08-24-2012, 11:12 AM   #14
We have six years, tooter - and since it's a bolt on that is easily removed, I think it presents no problem.
Would be interesting to roll into a test-only station though!
but yeah... VIDS!
Old 08-24-2012, 12:24 PM   #15
tooter
play every day
tooter's Avatar
but yeah... VIDS!
Thanks for the info, Garm.
You can tell it's been a while since we've had a new vehicle, with a 19 year old Hyundai and a 14 year old Tacoma.
Old 08-24-2012, 11:48 AM   #16
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Id that the ID of the midpipe? If so is there a lot of loss on the bottom end?
Old 08-24-2012, 12:31 PM   #17
xnamerxx
0-60 in slow
xnamerxx's Avatar
Yep the id of the pipe is 2.25" it feels like there's a loss of torque below 2k but no dyno to say for sure. Here's the video I just let it idle and took it around the block.
http://www.youtube.com/watch?v=KP2cX...ature=youtu.be
Old 08-24-2012, 05:51 PM   #18
tooter
play every day
tooter's Avatar
That sounds rad! Maybe you might consider dynoing it just for fun.
Check the California section. Harry, at HK Motorsports in Van Nuys will open up his shop on a Sunday if at least five cars want to to dyno runs for $70 each.
FS: Thunder Axle-back Exhaust for Yaris LB FunctionSpec Items for Sale by private party 38 06-03-2010 02:33 AM
Sedan - custom center exit exhaust. Herbicidal Performance Modifications 43 02-28-2010 11:36 PM
Custom Cat-Back exhaust Yaris TS CASTREX Yaris TS Talk 16 10-24-2008 12:56 PM
Exhaust exit jcove Cosmetic Modifications (Exterior/Interior) 17 05-09-2006 06:31 PM
