NGK Spark Plugs 25% Off @ Canadian Tire
Just givin' a heads up I see in the Crappy Tire flyer this week that NGK plugs are on sale for 25% off this week. Gonna go grab a set of NGK Iridiums. Does anyone know the part number off hand even? Anyways at ~130,000KM so thinking now would be a decent time to replace the original set, regardless that the manual states 192,000KM before the first replacement.
![]() ![]() Drives: '07 Yaris, '12 GLI Join Date: May 2007
The ones on sale that you want are either
BKR5EIX-11 in the packs of two or IFR5T-11 in the singles The IFR is the "OE Laser Iridium", the BKR is the "Iridium IX" series. http://www.ngksparkplugs.com/product...er_iridium.asp http://www.ngksparkplugs.com/product.../iridiumix.asp |
#3 | |
#4 | |
![]() ![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Aug 2010
So I just run v-groove plugs all the time now and change them every 10-20k kms.
2006 Saturn Ion Redline 2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold 2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped |
Thanks for the heads up. I will have to make a decision. You change your spark plugs that often though eh? I was thinking every 100,000KM would be sufficient enough?
#6 | |
Apparently copper plugs only last around 30k kms (just did some googling), but they conduct electricity better. With them being so cheap, the moment you notice a decrease in mileage is a good sign it's time for them to go, and considering how easy ours are to change, it should be a no-brainer.
| tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 10:44 AM |
| screw more psi in the tires. | thebarber | Fuel Economy Forum | 43 | 05-04-2009 05:46 PM |
| Where do I buy ngk iridium tip 7 heat spark plugs? | PETERPOOP | Performance Modifications | 23 | 03-08-2009 09:34 PM |
| FS: OEM NGK Spark Plugs | mikenacarato | Items for Sale by private party | 13 | 01-23-2009 05:05 PM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 08:09 PM |
