Old 09-30-2012, 09:58 PM   #1
dragoonmc
Drives: 07 hatchback
broken bolt extractor
So I changed my sparkplugs a while back and almost broke 2 bolts tightening down the coils.
well yesterday I double checked they were all tight and broke one off in the head. So I grabbed a screw extractor and drill bit and got the screw extractor in and then it broke.
I spent probably 2 hours trying to drill a hole for the bigger (correct) size screw extractor but that just wasn't working with how much harder the broken extractor was. I eventually ended up getting out the dremel and grinding the hole back centered and then grabbed a carbide tipped drill bit intended for glass. This ate right through the extractor and got me a nice hole for the correct screw extractor to bite into and the bolt came right out.
So lesson is use a carbide tipped bit if you break a screw extractor in a bolt.
dragoonmc is offline   Reply With Quote
Old 10-01-2012, 07:12 AM   #2
WTH? How tight did you think they had to be? Those should be barely past snug.
Lesson learned is use proper torque amounts for bolt/application.
Old 10-01-2012, 01:31 PM   #3
CoryM
Drives: 2009 5-door, 5-speed
I'm surprised that you were able to cut the broken extractor with a drill bit. Usually it's game over at that point. Did it actually drill a hole into the extractor or just kind of break it?
Warning - Broken control arm bolt! CB900F2 DIY / Maintenance / Service 460 08-23-2020 05:54 PM
Left lower suspension arm rear bolt broken. Kramruuk DIY / Maintenance / Service 1 07-07-2012 05:42 PM
How to replace a broken wheel stud Rami yaris DIY / Maintenance / Service 4 06-28-2012 05:34 PM
2 bolt alternator, lower pivot bolt jstantherprsn DIY / Maintenance / Service 7 04-12-2011 10:02 AM
