Old 10-07-2012, 11:02 PM   #1
DanMC
Drives: 2012 Toyota Yaris
Has anyone replaced the speakers in gen III Yaris yet ?
Hi, i was wondering if anyone has replaced the speakers (front and rear) in gen. III Yaris ?...if somebody has pictures of them it be even better. I'm curious if they are made by Fujitsu Ten (Eclipse) or not .
Thank you
Dan
DanMC is offline   Reply With Quote
Old 10-17-2012, 12:11 AM   #2
carolinablue
Drives: 2012
I replaced mine with a set of 6.5 inch 4 way 350 watt Pioneers that I bought on sale on Amazon, total expense for 4, $112. They sound really really clear and do a nice job of separating out sounds and are loud enough to run you out of the car. They could use a little more bass. I am thinking about adding a small subwoofer, or a small pair of sub woofers as well.
carolinablue is offline   Reply With Quote
Old 10-18-2012, 11:21 PM   #3
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
Did you use adapters??
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 10-24-2012, 08:29 PM   #4
muffin_top
Drives: 2012 Yaris SE 5MT
Thank you
Dan
Dan,
The OEM speakers do not appear to have been made by Fujitsu Ten. The markings look like possibly Pioneer or Matsushita (Panasonic). Either way, they suck something fierce.
Adapters will need to be fitted to insure proper spacing between the door panel and the window regulator. The Scosche SAT6 adapters fit best and increase the mounting depth to roughly 2.75 inches.
muffin_top is offline   Reply With Quote
Old 10-24-2012, 09:19 PM   #5
DanMC
Thank you muffin_top and carolinablue...i apreciate your replies.
Dan
Old 10-26-2012, 02:13 AM   #6
carolinablue
Drives: 2012
I used these adapters, purchased through Amazon. The SAT6 front adaters are an exact fit. Some cutting and drilling of the SAT69 rear adapters is necessary. Both will install with no modifications of the vehicle itself.
Old 11-08-2012, 10:39 AM   #7
FuuFuu
Drives: 11 Yaris 03 Ranger 81 Escort
I gutted the speakers from my old 11 Yaris I had left over to make adapters to fit in the 12 Yaris ;)
FuuFuu is offline   Reply With Quote
Old 11-17-2012, 07:34 PM   #8
shrek
Drives: 2012 5dr Manual Yaris
Here,
http://www.ebay.com.au/itm/SCOSCHE-S...1#ht_500wt_969
and would these work?
http://www.ebay.com.au/itm/PC2-824-T...ht_1402wt_1186
shrek is offline   Reply With Quote
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 12:25 PM
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
