Old 10-23-2012, 04:02 PM   #1
robertb1972
Drives: Yaris Sedan
BROKEN KEY
Man, I need help
I own a 2007 Yaris Sedan, base car, always had a base key without remote, a copy "Curtis TR-47 model". This key is broken now, and I just have a part of it. I also have another key (just a copy) that I kept sometime ago, but this one does not turn on the engine, can only be used to open/close the door (it was a base copy without transponder).
The big problem now is that I just opened the plastic of the "Curtis" and did not find any chip/transponder and now I need to turn on the engine the key copy that I have. I tried to turn the engine on using this key, and the other one by the side, but car does not start. I have no idea on how the engine turned on with a key without a transponder.
What to do now? How to start the car with this key?
Need help!
robertb1972 is offline   Reply With Quote
Old 10-23-2012, 04:22 PM   #2
kou
Drives: 08 lb
Does your spare key turn in the ignition just not start it? is your car stick? a toyota dealer can make you a key from your VIN #.
Old 10-23-2012, 04:24 PM   #3
kou
Drives: 08 lb
If your car is stick shift see if you can bump start it with the key in the ignition on position.
Old 10-23-2012, 04:43 PM   #4
robertb1972
Drives: Yaris Sedan
my car is automatic, and the key turns and all lights comes up, but car do not start, even with the old key together (side)
and the old key (brokne) does not have a chip or transponder inside, i dont know why
Old 10-23-2012, 05:35 PM   #5
If you look at your ignition switch, is the whole thing metal or is just the part that rotates with the key metal and the outer part plastic? That would say for sure if it is a transponder type.
It may be that the ignition switch is just worn out. You can turn the key to the ON position and then jump the grey wire to the pin with the two black wires to see if it will turn over.
The other possibility with it being AT is the park/neutral switch, which is actually located on the transmission.
Old 10-23-2012, 05:52 PM   #6
robertb1972
Drives: Yaris Sedan
Thumbs up
car just started with the copy key without the chip, dont know why, but started
i just removed the ecu cables and connected them again
if it happens again i will try this other option, jump the wires
thank you all for the help!!!!
2007 Yaris: looks like I only have a "valet" key. Options? choppa DIY / Maintenance / Service 11 11-21-2016 10:23 AM
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 06:32 PM
2010 Yaris Sedan - Need Key Programmed to the Immobilizer vst General Yaris / Vitz Discussion 0 04-17-2011 04:29 PM
Reemplazo Swichera yukardo Central and South America 3 04-03-2011 12:11 AM
Need remote key fraenx DIY / Maintenance / Service 1 06-26-2009 07:29 PM
