Old 12-04-2012, 09:20 PM   #1
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
Those of you with megan coilovers please chime in
I have a set of 150mm megan coilover rear springs..these will be replacing the original 190mm ones the kit came with...I have the rear shocks as low as they will go , however they are still too long and don't keep the spring in place under decompression..I am thinking of going with a 06 honda fit rear megan shock as it is 40mm shorter...please let me know what you guys think
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 12-04-2012, 10:42 PM   #2
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
See message
Old 12-05-2012, 03:06 AM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
must be a sedan thing..
-Derrick-
Old 12-05-2012, 12:22 PM   #4
DeathBeard
DeathBeard's Avatar
For me it's a liftback thing..Anyway below are pictures just taken...You can see even when the shock is fully maxed out on the lowest setting the spring is still a good 40-50mm too short
Proverbs 16:9
Old 12-05-2012, 12:23 PM   #5
DeathBeard
DeathBeard's Avatar
scary some of you would drive around like this, seems like a nightmare waiting to happen
Proverbs 16:9
Old 12-05-2012, 12:25 PM   #6
DeathBeard
DeathBeard's Avatar
Here is the 190mm spring for reference
Proverbs 16:9
Old 12-05-2012, 01:39 PM   #7
1.5
Form>Function
1.5's Avatar
Yeah Jason you can force it but it naturally like locks about 20mm+ out.
Deathbeard again my question is, when driving, when would your suspension ever be this unloaded? Are you jumping? Even on large bumps, the weight of your car is not going to travel against gravity that much to cause your springs to be fully unloaded.
Old 12-05-2012, 01:42 PM   #8
Jason@SportsCar
That should be an easy fix... Back the mount all the way out of the shock, cut the unneeded thread off, back the jam nut off to clean the cut threads, reinstall at lower height. If you need it to be even shorter you could find a thinner jam nut, there is not much of any load on it, or even just ditch the jam nut and go with loctite. With no spring on the shock there should be very little twisting force, and if the upper mount is tight it should not spin.
Old 12-05-2012, 05:35 PM   #9
DeathBeard
DeathBeard's Avatar
Can't say but I wouldn't risk it as it would be catastrophic at highway speeds, also certain driveways and lots of articulation can also make it pop out, megans kit has alot of improvement needed imo
Proverbs 16:9
Old 12-05-2012, 06:25 PM   #10
1.5
Form>Function
1.5's Avatar
I havnt had a problem at all yet. My fat ass keeps my springs tight lol There are always high tensile zipties
Old 12-05-2012, 12:37 PM   #11
Jason@SportsCar
You say you have them as low as they will go, but in the second image I still see a lot of thread showing. Can you not spin the lower mount into the body any further?
Old 12-05-2012, 05:31 PM   #12
DeathBeard
DeathBeard's Avatar
The bolt is maxed out and won't turn anymore as it is physically coming into contact with the damper itself
Proverbs 16:9
Old 12-05-2012, 05:35 PM   #13
Jason@SportsCar
Shorten the bolt.
Old 12-05-2012, 06:36 PM   #14
DeathBeard
DeathBeard's Avatar
Shorten the bolt.
I think I'm going this route
Proverbs 16:9
Old 12-05-2012, 06:41 PM   #15
Jason@SportsCar
Might as well... There is a damn good chance the "shorter" Fit application uses the same shock with a different lower mount - its not like they would actually build individual shocks for two applications that are nearly identical.
Old 12-05-2012, 01:51 PM   #16
1.5
Form>Function
1.5's Avatar
Yea I think thats what Miles is trying to do, for me, I dont have a need to make my shock any shorter, It never bottoms out and it has enough droop to allow my tires to fall back to earth if I do catch any air. I think he is trying to use his shocks to hold his springs in place even when the car is fully jacked up.
Old 12-05-2012, 01:54 PM   #17
Jason@SportsCar
My rears hold my springs in where the car is off the ground. I Have a 2" droop limiter installed inside the shock. Also negates the need for a heavy rear swaybar.
Old 12-05-2012, 02:05 PM   #18
1.5
Form>Function
1.5's Avatar
I would never do that with a daily, again. I already learned my lesson when I blew a shock because I shortened my shock so much it had less than 1" of droop. Miles now has blown his shock twice doing that. I just want to try and help deathbeard before he goes through the same pains lol
need help on megan coilovers chexmix Wheels, Tires and Suspension Forum sponsored by The Tire Rack 27 01-26-2016 04:13 AM
who got megan coilovers walt101786 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 04-04-2011 07:55 PM
Megan Coilovers $550 including install!!! Walter Items for Sale by private party 14 09-29-2010 12:01 PM
FS: Megan Coilovers and Megan Axleback Exhaust thebarber Items for Sale by private party 19 04-08-2010 04:06 PM
