Proud Goloof Hater (G)
Drives: Toyota Yaris T1 Join Date: Jul 2012
Rattles and some advice
Hello Guys
I have a 2009 T1 LB and I have Installed a Sony Xplod USB AUX Head Unit, 2000W Targa Amplifier and a 1000W 12" Pioneer Subwoofer with stock Tweeters and Mids. The issue im having is with Rattles.. at mid range sub frequency, the Rear Break light that fits at the top of the tailgate Rattles, as well as the Rear view Mirror and the Plastic cover by the Speedo and lastly some of the windows, Especially the drivers side door. Wiring isnt an issue however the car does need to be rewired (Next time dont ask a friend who thinks he knows what he's doing) The Second issue I have with my Interior is, is there any way I can install a switch to switch the amp and sub off from the drivers seat without having to switch the whole radio off or go into the head unit to switch it off. On the Sony Xplod head units its a mission and the amp stays on even if the sub is off, thus draining the battery and me having to (Very Embarassingly) kickstart my car.. Ive Noticed in the Center Console by the Door locking switch there are some unused switch mountings or bays (Whichever you prefer) just infront of the handbrake.. Can i use those, if so, Where can I get a switch? Also, Is this possible? Thanks for the Replies
They hear me before they see me-Pioneer 12" Champion Series Subwoofer -Targa 2000W 4 Channel amplifer - Sony Xplod GT45U Head Unit |
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
just mount a 12V toggle switch on the blue remote wire to the amp.
as for the rattles, buy a lexus. LOL. JKSJKS for the rear brake light, make sure its the rear brake light. you can pop off the 2 little caps on the rear brake light and tighten it down. mine was loose. Also the plastic pannel on the inside of the tailgate can rattle, i removed mine and filled it with some soft foam. Are you sure its the review mirror? on my car it was the passenger side air vent that sounded like it was the center mirror. as for the trim around the spedo, remove it and look at the wear marks on the spedo itself to see exactly where it is making contact. using a dremel or soemthing cut off the excess on the tim peice so it doesnt make contact anymore
my rearview mirror also rattles!
rly? how? which part? if its the joints i would recommed just putting some lithum grease on it bu that would be more of a squeek then a rattle.
Just unclip the mirror from the window (slide it up, i will not be responsible for broken things) and see if you can still hear it. this would also be the best way to put grease on the joints. Phaznet, I/ bet your car has what sounds to be 100 rattles every morning before the heat kicks in, lol. when my car is cold it sounds like im dragging my dash on the road behind me till it warms up.
Roadrunner Jr.
It sounds to me that your amplifier issue is a matter of proper wiring.
When you turn off your ignition the amplifier should turn off as well... Negating the need for a separate switch. You must have your turn on signal wire going into the power supply of the amplifier on a constant instead of the ignition...
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
Hi guys thanks for the replies
Should I send the car for Rewiring?? I dont mind the switch cause I think it'll look really cool especially one that looks like you've just activated something. Plus when im playing music with the car switched off i wouldnt mind the sub and amp to be off and just the mids running. Also, the whole messing with the panels im not so wild about cause I dont want to damage any of them badly. I think Ill just Put some stick on material to see where its catching. The rear view mirror i know is the problem cause I can see it rattling and i can feel it rattling too.. i see the Visor is starting to rattle as well but thats not a big issue. Also, Just wondering if i can fit more speakers to the car, a set of 6x9s( Not sure the European name) and maybe another 12" Woofer? Will the amp handle it or will I have to change? Thanks Guys for te replies.. Ill attach some Images of my Sound setup once i find out how to insert images [Cant upload from HDD :(]
#7 | |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
best part, you can wire them up to light up when you turn on your park lights.
Stage ...Base
Drives: Toyota Yaris LB '07 Join Date: Oct 2012
Sup Trishen
Check you a Durban boy also. Most likely it's the wiring that's a prob.. Take it to soundstation to get it required and have some deadedning put in place. Pm me and I'll organize you a contact to rewire for you, guaranteed not a bushmech job. As for pics, use photobucket.com or any other image hosting site. Leka mamz |
![]() ![]() Drives: Want a yaris Join Date: May 2012
How do you kick start your car?
Stage ...Base
roll/push your car whilst the handbrake is down then attempt to start the car whilst playing with the clutch and accelerator
Any links on how to remove the centre console completely?? I need to take my cigg lighter out, damn thing went bust on me recently.. so if its a cheap and easy fix why not?
Stage ...Base
Search button is your friend
