![]() Drives: yaris 06 Join Date: Dec 2012
HELP: New passenger side rear light rubber seal needed
My girlfriend's 06 yaris has had a leak for the last month or so. We have found that water is coming in through the passenger side rear light as a rubber seal is broken, (see picure).
Does anybody know where i could buy a replacement from as i have looked and looked and cannot find one. |
Some thin adhesive backed weather stripping from a home centre/hardware store should do the trick. Use short piece(s) to bridge the cap in the rubber seal.
#3 | |
![]() ![]() Drives: Yaris 1.33 litre 2011 Join Date: Dec 2009
Regards Geoff Peace. |
The gasket is a standard Toyota part, so you should be able to get one from your local Toyota dealer. There are many different part numbers for them based on year and market. If you can read the Toyota part number off of the back of your tail light, I can tell you what gasket part number goes with it.
Thanks guys, she is going to see the local dealer about the part. i just werent sure if you had to buy the hole light aswell, but apparently not.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
| "Airbag" center console light on 07 Sedan with side airbags | atebit | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 11-10-2006 06:10 PM |
