![]() ![]() Drives: new vitz Join Date: Apr 2010
Badly need help ............
okay , i had a Pioneer DEH-3950mp which was really good........the radio was receiving all the channels without any inconvenience. last month, i decided to buy a new Pioneer which is DEH-5450sd, bought and installed, everything was well, but i haven't checked the radio tuner at the buyer place. At home, the radio was unable to receive any channel, went to the dealer, tried another 5450, then a 8350, then a 2450............BUT all were same. When i shift back to my old DEh-3950mp....all good.
ANY suggestion please.......... |
CT scott where are you?
Stage ...Base
Drives: Toyota Yaris LB '07 Join Date: Oct 2012
Are you using the same harness ie the DEH-3950mp with the newer DEH-5450sd? it could be the problem...also could be the antenna not connected securely... just my opinions
It is probably the fact that the black wire on the OEM harness is not connected to the "power antenna output" on the new head unit's harness. The Yaris has an RF amplifier built into the antenna base, and if it is not powered the antenna is worthless.
Roadrunner Jr.
^X2
CT beat me to that answer
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
But i have plug the antenna wire well in the radio, but still nothing. Ct scott try to be a bit more clearer, am unable to understand you.
The antenna also has a separate power wire. It is the black wire on the blue radio connector.
OKay, so i just found out that in newer Yaris , the antenna already had the power together. So what shall i do?
What year is your Yaris, and did you measure the voltage on the wire to make sure that your headunit is really powering it?
mine is 2006, i dnt have any equipment to measure.
OK. If you want to try a test, since you don't have a meter, you can take the black wire from the factory blue colored connector and connect it to the grey wire, which is diagonally next to it on the connector.
So, i bought 1 like this
http://www.best-b2b.com/userimg/658/...ntenna-831.jpg and install it. By the way i got back to my DEH -3950mp, and by surprise it plays the fm just like the others. In some village it plays well whereas in some it doesn't which was not the case before. So i do't even know what to do? |
And ya the AM too has stopped working
#14 |
@Ctscott. Maybe a picture of the harness and a huge red arrow
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 |
#15 |
One thing I did not think of prior is the tuning spec for both radios. Is the new one rated for your area of the world, as the old one apparently was?
#16 |
Finally i had it connected, And it was obviously the BLACK wire. Thanks to CT scott and tohers. :)
| Headlight misting (badly) | Geoff Peace | DIY / Maintenance / Service | 9 | 04-30-2012 10:52 PM |
| Most popular brands/models for Gen Y - Yaris sedan #4 - American brands fair badly | Kal-El | General Yaris / Vitz Discussion | 2 | 07-09-2011 07:02 PM |
| Dwarf singing jonas brothers very badly | PETERPOOP | Off-topic / Other Cars / Everything else Discussions | 2 | 04-29-2009 07:54 PM |
| Need help badly looking for engine swap places in gta | Adriaan | Canada | 7 | 02-23-2009 08:14 PM |
