Old 01-12-2013, 06:37 AM   #1
liseky
Stoplight ahead!
Drives: 2007 Flinty Yaris Sedan
Sedan Trunk Lock Stuck
I tried searching this but couldn't come up with anything so here goes!
My trunk won't open if I stick my key into it and try to turn. It does work if I pull the latch from inside the driver's area. I'm using my master key, same one I have always used with no problems until now. Basically, I'll stick the key in vertically and try to turn clockwise, but it won't budge. Every once in a while, or with slight wiggling it will budge and open. I have already used lock lube but that didn't help either.
Any help is greatly appreciated! Thanks!
liseky is offline   Reply With Quote
Old 01-12-2013, 06:51 AM   #2
Do you have another key that hasn't been used much? Sometimes the key gets worn enough to make it no longer hit the tumblers correctly.
Old 01-12-2013, 07:08 AM   #3
liseky
Stoplight ahead!
The only other key I have in possession is a copy of my master from Walmart.
I just tried to use it and it definitely works better than my master but is not 100% and is almost impossible to turn counterclockwise to lock the trunk.
Is there anything I can do for a worn key?
Thanks for your quick response!
Old 01-12-2013, 07:31 AM   #4
You can go to a Toyota dealer and they can cut you a key based on your VIN. That way the key will match what the key was like when it was brand new.
Old 01-12-2013, 07:52 AM   #5
liseky
Stoplight ahead!
My master has the keyless lock fob...this will probably be pricey?
Oh well.
Thank you for all your help, CT!
Old 01-12-2013, 08:59 AM   #6
Oh well.
The actual key part is removable from the fob, so you should be able to get just the key part redone.
Old 01-15-2013, 05:35 PM   #7
liseky
Stoplight ahead!
Definitely confused. I can't seem to figure out how to separate the key from the fob...
http://i50.tinypic.com/16c5ic9.jpg
Old 01-15-2013, 07:10 PM   #8
The metal key with the plastic frame is purchasable as a separate part from the electronics.
Old 01-15-2013, 08:05 PM   #9
sroberts
sroberts's Avatar
Drives: 2007 Yaris Sedan
I just bought one and it worked great. The electronics swapped right over and the key cost me $3 to cut.
http://www.amazon.com/gp/product/B00...ls_o05_s00_i00
I am not allowed to put anything here because I do not have any ricey mods on my Yaris....
sroberts is offline   Reply With Quote
Old 01-15-2013, 08:53 PM   #10
liseky
Stoplight ahead!
Ah, gotcha. It was my misunderstanding.
I was looking at a thread about programming a new key. I think I just might buy that and have Toyota cut it. That way, I'll just have two! Thanks everyone!
Old 01-16-2013, 01:32 AM   #11
Perhaps needs lubrication?
Old 01-16-2013, 02:44 AM   #12
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
that's what she said.
Old 01-16-2013, 03:21 AM   #13
-____________-
Old 01-16-2013, 01:23 PM   #14
liseky
Stoplight ahead!
Already tried that. The key itself slips in and slides out pretty easily...
Old 01-16-2013, 11:49 PM   #15
liseky
Stoplight ahead!
Anybody know the part number for the OEM key shell without transponder chip?
Old 02-01-2013, 10:11 PM   #16
bairjo
Maybe the ribs of key are wore down from to much use and just not affective any longer...
Old 02-01-2013, 02:45 PM   #17
brg88tx
Drives: 07 Yaris Sedan, Auto
i bet the key that would not work on the trunk was the valet key. they usually have a slight curve to them. when i bought my car used it only had one key and it was the valet key. they will open doors and start car but will not work on trunk.
brg88tx is offline   Reply With Quote
Old 02-01-2013, 02:48 PM   #18
liseky
Stoplight ahead!
Nah, I bought my car new. I received the master key with fob and spare keys. The master key has opened the trunk fine for over 6 years.
Sedan Trunk Lift eggyolk808 DIY / Maintenance / Service 9 09-11-2013 06:19 PM
Sedan Chrome Trunk Applique codymclelland Cosmetic Modifications (Exterior/Interior) 2 05-11-2009 11:22 AM
