![]() Drives: Car Join Date: Dec 2011
Lower alternator bolt won't go back in, help!
Good morning,
I'm changing the accessory belt and have the old off and new back on. the manual says to set the tension, then tighten the top pivot bolt, followed the lower bolt. On first try, i couldn't get the lower bolt to thread in properly. Seems it was off slightly which is odd because it looks like a straight shot through the front/back sides of the alternator. I tinkered with the pivot bolt and tension a bit, and now i can't get the bolt to go in at all. Seems it goes in half an inch and then I'm stymied. I've tried removing the pivot bolt and belt entirely, and am now sliding the alternator front to back while trying to get the lower bolt in, but it's simply not going. Any ideas? |
Stick something smaller through (like a screwdriver) to make sure you have the holes somewhat lined up. Once that goes through OK, move up to something closer to the bolt's diameter. Also, check to make sure that the lower bolt is not bowed.
#3 | |
Job is complete! Thank you. |
Yeah, there is zero tolerance for miss-alignment.
| Help! Right side lower control arm removal | RUBBERDIPSTICK | DIY / Maintenance / Service | 15 | 12-27-2018 01:29 PM |
| Lower control arm replacement 2005 Echo ? | Infinitrium | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-27-2012 03:23 PM |
| Car back from body shop....Dust in the paint? | Hamster | Wash, Wax, Detailing, Exterior Repairs | 32 | 09-07-2011 02:39 PM |
| Why this girl will never "race" on back roads again .... | JBougie | Off-topic / Other Cars / Everything else Discussions | 11 | 11-18-2010 02:10 PM |
| Converting from Custom Wheels back to stock!!! | daddz07 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 09-23-2010 08:45 PM |
