![]() ![]() Drives: Yaris 1.33 litre 2011 Join Date: Dec 2009
Spark plug torque
Does anyone know the correct torque for the spark plugs on the new Yaris. 1.33 litre. 1NR-FE engine? I have the information the plugs are ILKAR7B11. (NGK). and the torque is 15 - 20 Nm. This seems high to me, can anyone supply the correct information please?
Regards Geoff Peace. |
38. INSTALL SPARK PLUG
(a) Using a 14 mm spark plug wrench, install the 4 spark plugs. Torque: 20 N•m (204 kgf•cm, 15ft•lbf)
Winterizing
Drives: 2010 Toyota Yaris Hatchback Join Date: Oct 2011
I have an '08 hatch back. 1.5 liter. My spark plugs don't fit in a 14 or 15 mm socket. They fit in a 16 mm socket.
_ I could be wrong, it could be the burnt carbon, but I think it is taking me 22 ft*lbs to take the old ones off. _ I'm going with 15 ft*lbs of torque. Is 15 ft*lbs incorrect? _ Does the addition of an extension have to be taken into account when calculating the torque? _ there is this that I found too: _ http://www.autolite.com/media/11853/torquespecs.pdf _ It only gives specs for 14 or 17 mm. Is this a sign that even though mine don't fit in a 14 mm socket, that they are called that anyway?
33.7 mpg in PA
Honestly ur putting way to much thought in to it ...just change ur plugs ,use antsieze and snug them up that's it
sent from my S4 on Mars |
Winterizing
Thanks, I did use antiseize btw. I'm still curious to any other answers though.
33.7 mpg in PA
![]() ![]() Drives: 06' Yaris 1.3l Join Date: Jul 2014
apparently NGK Reccomend AGAINST the use of anti-seize provided you don't leave them for 150K+ miles. Nonetheless I used it when replacing my stock ones with NGK Iridium IX plugs..
![]() Drives: 08' Yaris, 03' Sequoia Join Date: Jul 2009
Spark plugs x Cylinder head assembly
18 N*m 13 ft.*lbf |
Oldie
Drives: 2012 yaris sedan Join Date: Apr 2021
Is a couple grunts about the same?
| Spark Plug Problem | TickleTimeTim | DIY / Maintenance / Service | 15 | 09-07-2013 09:18 AM |
| spark plug | momo-yx | DIY / Maintenance / Service | 0 | 03-15-2012 04:35 PM |
| Spark plug change . | Dc1011 | DIY / Maintenance / Service | 2 | 01-29-2012 01:55 PM |
| Spark Plug | ubospawis | Middle East | 11 | 09-01-2010 08:55 AM |
| spark plug | 33lam | Performance Modifications | 25 | 12-23-2008 04:40 PM |
