MPG Tip
I got this from a post on my motorcycles forum:
One of the most important tips is to fill up when your gas tank is HALF FULL. The reason for this is the more gas you have in your tank the less air occupying its empty space. Gasoline evaporates faster than you can imagine. Gasoline storage tanks have an internal floating roof. This roof serves as zero clearance between the gas and the atmosphere, so it minimizes the evaporation. Unlike service stations, here where I work, every truck that we load is temperature compensated so that every gallon is actually the exact amount.
#2 | |
Anecdotally, I see an inkling of what you're saying when I do less driving and take longer to 'go through' a tank. On those tanks (ones that say, don't get to empty for 2 weeks or so) it seems to be harder to get over 40 combined on a tank, where it is usually routine. |
Im not saying it just reporting it for comment. Maybe its so. But I dont think air can get into a gas tank very much for the gas to evap into. Theres charcoal filters to trap it anyway. Whether that works is another story.
What I cant BELIEVE is that people wait until the tank is empty to fill it up! Good way to run out of gas! And they TRUST that idiot blinking light! Like you Im dubious this saves fuel but if it helps people to not run their tank dry before filling up its all good. MAybe manufactures should incorporate a floating cover for the gas inside the gas tank like the ones in gas station tanks? ![]() MAybe Prius will do it to go along with all thier other nit wit features.
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
I don't think that the half tank makes a difference because our cars run (partially) on those gas tank vapors from being pulled into the engine by manifold vacuum to be burned. That's the whole idea of the tank's sealed vapor recovery system. I do know that you don't want to run the tank dry as that can damage the fuel pump.
#5 | |
I don't. I, like Mad Max, keep a close eye on how many miles I've traveled on the current tank and know from experience the minimum amount I can count on from how my Yaris has performed in the past.. I also include (a little bit) the bar drop interval for that particular tank. This method has proven to be very accurate in my case.
I am not a motorcycle driver or owner but they probably don't have an evap recovery system.
This may be valid on a bike but I can't see the validity on a car (or at least newer ones). I also think running the fuel down isn't bad. I know about how many miles I can go on a tank and fill accordingly. I usually have a gallon or so left in the tank (which is roughly 40 more miles). I tend to fill up at least once weekly (actually my other car) and couldn't imagine filling twice a week just for the added time it takes. I drive around 500 miles weekly so I am probably not the norm. |
#7 | |
![]() ![]() ![]() ![]() Drives: 2013 Yaris Join Date: Oct 2011
Ditto, sounds like we do the same, lol. I keep my trip meter on display all the time and I reset it every fill up to calculate :) |
#10 | ||
play every day
My 1996 BMW R11GS had a charcoal filter to trap gas as does my 2004 ST13.
| Save thousands and BIG MPG almost PRIUS | jay cobbs | New YARIS Purchase Forum | 6 | 08-28-2012 09:38 PM |
| Why sub-compacts and compacts get almost the same MPG | Kal-El | Off-topic / Other Cars / Everything else Discussions | 0 | 08-11-2011 12:51 AM |
| 3000 mi Summer Trip Log...MPG included! | slothman86 | Fuel Economy Forum | 14 | 07-20-2010 01:15 PM |
| Better MPG in the City vs. Hwy | Loren | Fuel Economy Forum | 21 | 01-29-2010 12:49 PM |
| My progression into hypermiling | BailOut | General Yaris / Vitz Discussion | 8 | 10-13-2009 07:31 PM |
