Old 03-25-2013, 01:54 PM   #1
Lerico
Drives: Yaris 2012
Backup Camera
Just want to share what I have done over the weekend...
I just installed a backup camera on my girlfriend's Yaris. The car came with a hole for the camera, so I went and bought a 3rd party camera that fits right in the OEM location. It looks OEM from the outside. I am planning to get a double-din radio to display the image, but right now just settling on 4.3inch LCD screen.
Install was relatively easy. It took about 2 hours total to wire up everything neatly. The system works just like OEM, the camera is on only when the car is in reverse.
It cost me about $35 for the camera and about $25 for the LCD screen.
Here is a pic of your hatch door and the location to install the camera.
Lerico is offline   Reply With Quote
Old 04-10-2013, 05:50 PM   #2
Midon
Mod Freak
Drives: 88 MR2 GT
Were did u get the camera?
Midon is offline   Reply With Quote
Old 04-10-2013, 07:53 PM   #3
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
Pic of hole from outside please.
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 04-10-2013, 09:06 PM   #4
screenprintr
screenprintr's Avatar
Drives: 2010 Toyota Yaris
I have those cameras from eBay. Search eBay for E328. Comes with a cable power adapter you have to solder, and RCA line. The RCA line is about 17 feet. I use the cameras for something else.
I have about 30 to 40 cables if anyone needs an extra. This is the cable that runs from the Camera to the monitor.
For those that don't want to run cables they also have wireless.
screenprintr is offline   Reply With Quote
Old 05-03-2013, 05:53 PM   #5
Lerico
Drives: Yaris 2012
http://www.aliexpress.com/item/SONY-...536788227.html
This is the exact camera I got and it fits perfectly. It basically fill up the hole in that exact shape. Very good day and night quality too. I don't know if it's really that Sony CCD that makes the difference.
Old 05-28-2013, 05:23 PM   #6
asalgado011
Drives: Yaris Hatchback
hello, may I ask you if the connector that came from vehicle for the OEM camera at the tailgate (close to the hole where the camera was installed) did you wire something there (to that connector?) if yes, can you tell me what and how? my Yaris has on that connector 4 cables, pink, brown, black and blue. Also, where in the car you placed the monitor? thanks.
asalgado011 is offline   Reply With Quote
Old 05-28-2013, 07:17 PM   #7
screenprintr
Don't know about the Yaris wiring, but the camera has a diagram. Also you can put the Monitor on your rearview mirror or on the dash.
Some people replace the radio with a computer display/radio/stero.
Old 10-09-2014, 02:02 PM   #8
ucsmfu
Drives: yaris le
would it work if I tap the reverse camera to the reverse signal light ?
http://i.imgur.com/45uGfLx.png (red wire ?)
or is there a cleaner install for a connector in the fuse box ?
Thanks
ucsmfu is offline   Reply With Quote
Old 10-09-2014, 07:33 PM   #9
mr_miles
Drives: 2013 Yaris
If I'm not mistaken, on my yaris that's where the keyhole is. I wonder if I can stuff a camera there instead. Mind posting picture of it on the outside?
Old 10-09-2014, 09:50 PM   #10
JustPassinThru
Drives: No more Yaris
It's amazing.
When I was a bus driver/college student in the 1980s (the University ran the city bus line and all its drivers were work-study students) we had ONE bus with a back-up camera. A REALLY BIG DEAL; and it cost more than a new small car. Camera on the back; miniature CRT screen on the dash.
We were told not to turn it on unless actually backing up - because sunshine would hurt the tubes and electronics of the camera. Now this was not old equipment - the bus was a 1985 Gillig, the equipment put on in 1986 when the bus was placed in service.
Today those things are the size of a big bolt - and you can buy the hardware for less than $100.
JustPassinThru is offline   Reply With Quote
Old 10-09-2014, 10:40 PM   #11
vrait
vrait's Avatar
By 2017 or 2018 back-up cameras will be mandetory on all cars in the US. Hence why its starting to be standard on a lot of cars now.
vrait is offline   Reply With Quote
Old 10-18-2014, 04:19 PM   #12
Lerico
Drives: Yaris 2012
ImageUploadedByTapatalk1413663503.558522.jpgImageUploadedByTapatalk1413663516.397343.jpgImageUploadedByTapatalk1413663581.032310.jpg
Here are the photo of the camera from the outside. And a photo of the lcd mirror.
Old 10-18-2014, 04:20 PM   #13
Lerico
Drives: Yaris 2012
Have been using the camera since March 2013. So far no problem at all.
Old 10-18-2014, 07:12 PM   #14
ucsmfu
Drives: yaris le
which camera did you buy again ?
Perfect fit ?
Old 10-20-2014, 12:37 PM   #15
Eduardo_mty
ucsmfu, i bought this
http://www.fedomcn.com/sdp/717381/4/...ew_Camera.html.
i cant remove that black plastic cover in the car, then i did a drill, to fit that screw.
Eduardo_mty is offline   Reply With Quote
Old 12-11-2014, 03:42 AM   #16
ucsmfu
Drives: yaris le
Have you installed your reverse camera yet ?
How did you feed the wires through the trunk and into the rubber grommet ?
thanks
Old 10-20-2014, 09:23 PM   #17
Lerico
Drives: Yaris 2012
I use the camera list in post #5. It is designed for Toyota. It's snaps right into the factory camera slot. It's not an universal camera.
Old 10-21-2014, 12:54 AM   #18
ucsmfu
Drives: yaris le
are u located in Vancouver, BC as well Lerico ?
backup camera! yarismo DIY / Maintenance / Service 10 07-23-2012 01:22 PM
DIY Camera Mount -- No Cost Version KCALB SIRAY DIY / Maintenance / Service 20 06-08-2009 03:12 PM
