Old 04-08-2013, 10:09 PM   #1
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
VW rims on Yaris?
will the VW rims work on Yaris ..14 inch up.
Old 04-08-2013, 10:15 PM   #2
4x100 VW wheels will fit. Many VW wheels have a ET33, ET35 or ET38, so they will tuck into the car 1cm or less than OEM wheels on a Yaris.
Old 04-08-2013, 10:23 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
i thought lower the ET number the more the wheel goes out more flush with the fender...correct me if im wrong. Running a 35 to 38 ET should be fine i would think....and ty for the info, also anyone try and actually run VW rims on Yaris, if so pics would be great.
Old 04-08-2013, 10:25 PM   #4
Yes, lower the offset, the more outward the rim will be. This is, of course, comparing two wheel of the same width.
Old 04-08-2013, 10:24 PM   #5
Make sure the center bore size is the same size, 54.1mm, or bigger. If it's smaller, it won't work.
Old 04-08-2013, 10:25 PM   #6
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
true on that , one can always get hub centering rings.
Old 04-08-2013, 10:27 PM   #7
Not if it's smaller than 54.1mm. If it's smaller, you'd have to get adapter wheel spacers that goes from less than 54.1mm to 54.1mm. My friend had to do that with his VS-XX. If it's larger, then you can get hubcentric rings (don't have to, but it's suggested).
Old 04-08-2013, 10:28 PM   #8
I always reverse the direction of offset. VW are typically 57.1mm for bore.
Old 04-08-2013, 10:30 PM   #9
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
so one should be able to get centering rings in size down lets say from 57.1 to 54.1
just found some ..57.1 to 54.1...:)
Old 04-08-2013, 10:35 PM   #10
Yes. That should be an easy hubcentric ring size to find.
Old 09-08-2013, 12:01 AM   #11
yak
yak
Drives: 2007 5 dr yaris
I'm running 14" VW Rims & 205 60 14 rubber
cheers
yak
yak is offline   Reply With Quote
Old 09-08-2013, 03:08 AM   #12
nookandcrannycar
A singular example of the very newest model/generation of Bug/Beetle coupe (not convertible) was parked next to my Yaris at Starbucks today. It had what was trying to be a modern version of those original saucer/observatory dome/half sphere Beetle wheel covers on it. I liked the previous 'model/generation' of Bug/Beetle, but not this one....and the wheels don't help....the totality/result = an ugly mess....might be markedly different on a Yaris, though......would certainly be unique .
Old 09-15-2013, 01:12 AM   #13
nookandcrannycar
^^^^^ Wheels and car color make a big difference on the newest Bug. The one mentioned above was a terrible color that seemed to be the traditional VW Robin's Egg Blue, but with an equal mixture of 'Puke Grey'. A couple of days later I saw a new brighter blue Turbo Bug and I liked the look of that car. Earlier today (within 5 minutes of each other) I saw a dark greyish new Turbo Bug (liked the look) and then a white standard/non turbo new Bug that had the same wheels and fender treatment that Turbo Bugs do (also liked the look).
Old 09-08-2013, 04:28 PM   #14
DINOeggxo
DINOeggxo's Avatar
Drives: white yaris hatchback.
VW wheels totally work!
my wheels are 4x100 BBS RM that were a factory option on MK2 (1985-1992) VW gti's. naturally i made my wider but still no issues
just make sure the offset is good and you wont have a problem!
DINOeggxo is offline   Reply With Quote
08 Yaris w/18" rims need advice greenbid Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 03-13-2012 12:43 PM
OEM yaris rims frog13 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 07-01-2010 07:07 PM
Silver Yaris w/ Black rims Spotted ScubaSteve Canada 3 07-05-2009 01:11 PM
