Old 04-09-2013, 02:27 PM   #1
aeme
Drives: platz 2002
Red face Problem with transmission
Hi all first of all let me thank you in advance for reading this topic pass.
Well it turns out that in trying to get in the car is like changing the shift lever touches against something, that is given to all but feels more changes to get into 1st, 2nd, and 3rd place and slightly.
It is as if to bite changes, only plays into something, after 1 second of pressing the lever, and enters the change happens. I would like to know the possible solutions to this.
Thank you very much.
Artemio Morales
San Lorenzo - Paraguay
aeme is offline   Reply With Quote
Old 04-09-2013, 02:30 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
how many KM or Miles on it? Have you ever changed the fluid? Have you ever lubed the pivots on the end of the shift cables?
Old 04-10-2013, 02:56 PM   #3
Amdkt7
Returning to Toyota
Drives: 2013 L 3dr MT
You are feeling the synchronizers in action. The synchronizers match the gear speeds before letting the gears mesh.
There are a number of possible things that could cause hard shifting:
Check this web site:
http://www.freeasestudyguides.com/ha...-problems.html
Not mention in the web site is changing the fluid. The wrong type fluid will cause hard shifting, or if the fluid is too old.
The clutch should be clearly dis-engaging the engine. You can feel it if it is not. With the car in gear you should be able to let the clutch out part ways before you feel the car start to move, or the engine slow down.
Shift linkages can be not adjusted right, too tight, or too loose.
Or the transmission maybe due for a rebuild.
Amdkt7 is offline   Reply With Quote
Old 04-10-2013, 02:58 PM   #4
Amdkt7
Returning to Toyota
I had a KIA that had a bad transmission. Replaced under warranty. The new transmission always had a hard time shifting from 2nd to 3rd when cold. I never could get the dealer to admit there was a problem, however I got 110K miles out of it before I traded it, so it was not a problem.
Old 04-11-2013, 09:02 AM   #5
aeme
Drives: platz 2002
Is Japanese, by the way Paraguay will have altered the car's mileage.
Now has 45.000.km and the car is 2001. is impossible that mileage.
I estimate is around 110,000 km
Since I bought it a year ago has the same problem.
The second day will change the gearbox oil, use oil Vollsynthetisches liquimolly Getriebeöl (GL 5) SAE 75 W-90.
But it did not improve anything.
That I never did, how I do?
Now I see that website. The strange thing is that I spend a year and as usual, did not worsen or improve.
The car is 2001, do not think that the factory has come like that.
Thank you very much for your replies gentlemen, I apologize if I speak wrong, in my country do not speak English and I was a bit complicated. Greetings.
Old 04-11-2013, 09:11 AM   #6
Bluevitz-rs
These transmissions do not like (GL5) fluid. You need to use GL4. That could be most of your problem. And the linkage private will be behind the airbox.
Old 04-11-2013, 01:56 PM   #7
aeme
Drives: platz 2002
In that influence the oil change GL5 to GL4? In May met 20.000 km when i change the oil of the gearbox.
Problem Starting Car drunkwithwords General Yaris / Vitz Discussion 3 07-21-2010 04:01 PM
Yaris Central Locking Problem pbasuita UK 0 07-10-2010 03:46 AM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 08:11 PM
Transmission designed for 10-15 min cold start delay Ironwill5 DIY / Maintenance / Service 29 12-03-2009 08:08 PM
