![]() Drives: 2008 yaris hatchback Join Date: Apr 2013
anyone else have this door lock problem?
So I have the 3 door hatchback. On 2 of the doors already, the locks have become jammed sort of. Well, on my back hatch lock, the key goes in but doesn't turn to unlock so the hatch is basically stuck.
Then on the passenger side, the key will work to lock the door if its unlocked but it wont unlock the door. The driver side is fine, it will both lock and unlock. However, if that one messes up too, Im kinda locked out! I tried using lubricant spray in the locks and that didnt seem to do anything. My next step might be getting a new key cut to see if it works better than my current key but not sure if that will help at all. Finally another option is getting actuators installed and using power locks. That would work, but very expensive option. Anyone else ever have this strange problem? This is the only car this has ever happened with for me. |
#2 | |
Yeah Scott I was thinking that too, especially since it appears to not be the original key, but a copy. That's all the guy who sold it to me gave me. Ok thanks buddy I'll try that.
For the trunk when you turn the key is there resistance or does it turn pretty freely, On the lock mechanism there is a plastic piece that holds the rod in place that may have come or broke may not need an entire latch assembly for the door passenger door. Can you lock and unlock it using the tab on the door near the inner handle , it may be the same issue the rod has become disconnected from the latch mechanism.
I dont know the part number off hand for the plastic clip maybe ct scott can follow up for that one. But typically its about a 5 dollar part. Looks something like this ![]() Might be something you could check/repair yourself. There are several diys on the forum on how to remove the door. edit - Sorry didnt fully read your post was looking at it from a smartphone i would try with a another key for the trunk, for your door does the key turn at all when you try to unlock it or does it feel jammed same as the rear trunk Last edited by YarisSedan; 04-25-2013 at 03:05 PM. |
Got the new key cut and now all doors open, yay! The hatch hasn't opened in months. I'm about to install a stereo/sub so I felt I had to stop procrastinating because it would make it twice as hard without all the doors opening when I needed them to. Thanks guys
| Problem with electronic door lock | new-yaris-owner | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 08-05-2012 05:12 PM |
| Problem with my car | rakhan01 | DIY / Maintenance / Service | 8 | 12-03-2010 05:12 AM |
| Problem Starting Car | drunkwithwords | General Yaris / Vitz Discussion | 3 | 07-21-2010 04:01 PM |
| Launching @ 4Krpm problem .... need tips | Parmas | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 12-30-2009 08:11 PM |
| How can I get in touch with Toyota Regional Offices in Houston? | woof | DIY / Maintenance / Service | 11 | 11-28-2009 09:29 PM |
