Old 05-04-2013, 02:00 AM   #1
Steph85be
YTS ***** member
Drives: 2003 Toyota Yaris TS
FS: Cylinder head/Camshafts 1NZ/2NZ-FE
Hello all,
I'm selling a machined and polished cylinder head with regrindered camshafts for 1NZ and 2NZ-FE engines.
Here are the spec :
-regrindered camshaft (254° / 9.5mm Intake and 250° / 9.3mm Exhaust) the Toyota OEM is 8.8mm of lifter and IN 225° EX 224° of durations.
-3 angle valve seat
-heavy duty valve spring are MWR , this is the spec
1.300 -55 lbs (Stock are 37.1 lbs)
.900” 105 lbs (Stock are 71lbs)
Coil bind -.795”
tested up to 7200 RPM
You'll need your own camshafts brackets.
The price is 600$ + shipping cost
Steph85be is offline   Reply With Quote
Old 05-04-2013, 09:35 AM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
1) Reason for sale?
2) You are willing to do international shipping?
3) Methods of payment accepted?
4) What were you goals when you had the work done?
5) Was a well known company the ones that performed the work?
6) Does the company that did the work have a website that can be referenced?
Old 05-04-2013, 09:41 AM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
^^what he said.
Prob need some more info on who did the work. Mainly because you are selling something that would really cost alot of money fairly cheap. And also you only have 3 posts. Not saying you are trying to scam anyone. But some kinda reference that we can contact that did the work.
Looks clean and a great price if its legit
-Derrick-
Old 05-07-2013, 03:50 PM   #4
Steph85be
YTS ***** member
Yes, I have only 3 messages here because I live in Belgium, I speak French and a bit English. I'm serious, don't worry about that.
The head has been done by Giupo. Maybe you know him here... A great job, but I've to sell it because I need some money (family reason). It's a unique part so.
Of course international shipping will be done. I think payment with paypal is easy.
I have other parts for sell like E-manage blue, Camcon VVTI, AFR Innovate LC1... you can contact me for info.
Thanks
Old 05-07-2013, 04:13 PM   #5
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
Old 05-07-2013, 05:46 PM   #6
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
600 + shipping
Old 05-07-2013, 06:25 PM   #7
Let's see some pictures of the head showing the ports, please.
Stock valves or aftermarket?
Are there any head flow tests you can post? or is it just polished and not ported?
I'm sure you have a lot of interest and will get a sale if you show the product more completely. Head work must be done correctly and returning this is obviously a problem if it's not right.
Old 05-08-2013, 01:37 PM   #8
Steph85be
YTS ***** member
The valves are stock but valve springs and valve seats are aftermarket.
Yes I have other pictures, I'm going to post them this evening ;)
Polished, not ported.
Old 05-09-2013, 04:53 PM   #9
Steph85be
YTS ***** member
Old 05-09-2013, 05:05 PM   #10
This means it was installed on a car? Was it tested on a dyno?
How long/How many miles/etc. etc.
Didn't Giupo blow up that motor?
Old 05-12-2013, 04:04 AM   #11
Steph85be
YTS ***** member
I'm going to send a MP to Giupo for that questions ;)
Old 05-12-2013, 11:23 AM   #12
no problem. I figure if all of the information gets posted, you are more likely to get a sale on it.
Old 05-27-2013, 02:00 PM   #13
Steph85be
YTS ***** member
Hello all,
Sorry for delay. Here is Giupo's answer to your questions :
Hi Steph,
I'm well[...]
The Head is almost new, have real only 13000km, this is the last alu melting for yaris ts '05, you could check on cylinder head the toyota date mark. I haven't installed and tested directly on dyno this cylinder head but I installed a cylinder head with the same characteristics on my old turbo setup (engine built and turbo with greddy at 1.1 bar of boost) I got 216hp is a very good result for this setup.
regards
Giupo
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
Cylinder head bolt removal (Sequence) pozzydrive DIY / Maintenance / Service 1 10-19-2010 09:00 AM
DIY Hood Cylinder churp Cosmetic Modifications (Exterior/Interior) 46 06-25-2007 05:46 AM
Canada Only - Maybe a $1000 enviro rebate on Yaris> MDF New YARIS Purchase Forum 45 05-01-2007 08:17 PM
