![]() ![]() Drives: LB Join Date: Oct 2008
LOTEK Springs installed.
Decided to be a guinea pig and tried these ebay springs out.
Picked them up for $80 shipped to my door. ![]() They claim to be a -1.9" drop front and rear. I have no idea what the spring rates are. Here is a before pic. ![]() 4x4 status. Then about a 45 minutes later here is the end result ![]() Another one. ![]() They are just as low as my tein s-techs were. The ride is comparable. Handling is way better then stock. Happy !
You did 4 springs in 45 min.!
![]() Will be interesting to see how well the powdercoat stands up.
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
![]() ![]() ![]() Drives: 09 Blizzard Pearl RS LB Join Date: Sep 2009
Nice..need to see a speedrun on the 45 minute job though.
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” ― Ayrton Senna |
The rears take 5 minutes, you don't even have to take off the wheels. 15 min per a corner in the front. I've done it many times already, plus the use air tools makes it wicked fast!
toyota
did you have to take out the plastic panel and the windshield wipers.. coz its kinna hard to get to that hex nut that requires hex keys...plus the bolt around it..
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!! "Horsepower is how fast you hit the object. Torque is how far you move that object.." |
^ Not if you have a 17mm OFFSET box wrench.
![]() ![]() ![]() ![]() Drives: 2013 Yaris Join Date: Oct 2011
Offset box wrenches are the best inventions ever.
![]() ![]() ![]() Drives: 2010 Yaris HB Blazin' Blue Join Date: Feb 2011
You must have mighty small hands!!
I had to remove all the cowl pieces just to get enough room for using the 6mm allen wrench, then again all mine are T-handle! Now that I know the trick, it will be much easier next time, even still, it only took a few hours to change 2 struts/springs and 2 shocks/springs, didn't think that was too bad for an old man!!racerb
racerb '86 Celica GT '87 Celica GT-S '98 Rav4L '01 Tundra SR5 |
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
ahhh air tools lol it takes 15 minutes just to work some of the bolts off on my fronts lol
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
It took me nearly 12 hours to do my suspension job. About 10 trips to the hardware store trying to find a dang wrench that would remove that nut on top of the front towers.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Looks like the rear springs need about a 10mm spacer
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#14 |
Yeah i lost the rubber pieces a few installs ago. its just metal on metal. After riding around for a few days the ride is ok. Its not as nice as my tein springs were. The teins gave a smoother ride, these feel the road alot more.
#15 |
Form>Function
I agree with Malibu. I really like the low you get in the rear but it looks awkward since the front doesnt go as low.
#16 |
![]() ![]() Drives: black titty Join Date: Jun 2013
so 2 months later how are these? can we get an update?
#17 |
Henry Mak
Drives: 2009 Toyota Yaris 2dr-hatchbk Join Date: Aug 2012
Did you have to cut the bump stop? How is doing now?
| Micro Image lowering springs 1.8" drop | markylicious | Middle East | 144 | 10-30-2011 02:18 AM |
| NEW Springs | CAyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 32 | 06-25-2011 11:37 AM |
| have problem ! Installed tokico/eiback springs | annn | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 26 | 12-27-2010 01:59 AM |
| Done! D2 Brake System, Tein Springs and H&R Wheel Spacers Installed | RedVitz | Photo-Video-Media Gallery | 18 | 10-09-2010 04:36 PM |
| What springs should I get? Help! | CtrlAltDefeat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 01-26-2009 07:32 PM |
