Making a engine wiring harness
Hey guys, I would like to purchase a aem EMS standalone and Im planning to make a fresh new harness for it.
There are some OEM sensors that I will keep to run the engine, by exemple; -Crank position sensor -Cam position sensor -VVTI solenoid -PWM on the TB -TPS on the TB I have all the sensors, all I need are 2 pieces; The plastic clip that hook up directly to those sensors and the little metal connector that crimp to your wire and slip into the plastic connector. I don't want any solder, I want a fresh new harness just like a OEM one. Where can I find those connectors? Here is a nice website I found but it doesnt say much about the connectors and they mostly look all the same... http://www.automotivewiringsystems.c...6-products.htm |
Are you looking specifically for the connectors for each of the sensors that you listed? If so, I believe that I have all of them on hand.
#3 | |
Others gonna be AEM, so no need for them; -water temp -MAP If I forget some I will post them later! Thats a blast you have it all... What about the metal pins that I need to go into the connectors?? I guess I will need special crimper tool. Thanks! Also, I have a echo, so my TB is a drive by cable. Not the electronics one Last edited by maxthehax; 05-30-2013 at 09:20 PM. |
#4 | |
The TPS connector is different. The Toyota part number for the shell is: 90980-11261 The Idle Air Control connector (what you called the PWM) shell is: 90980-11145 The Crank, Cam, and OCV (VVTI) are the same for the Yaris and Echo.
#5 | |
I am currently working a bit on my yaris engine I have on a stand. I already have most of the connectors with butted wires. So that mean I could buy the piece of wire already crimped to make my connection. That require removing the old wires from each connectors, is that easy to do? |
#6 | |
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 04:22 AM |
| Engine noise and Oil Lamp on | bieniman | DIY / Maintenance / Service | 21 | 12-12-2010 11:47 PM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
| YARIS Wiring Harness for Sale | Lowfront | Items for Sale by private party | 13 | 10-11-2006 03:02 PM |
