Old 10-04-2013, 02:13 PM   #1
susucosp
Drives: toyota yaris
need to change the rear shocks
i have a 2008 yaris 3 door hatchback automatic need to change the rear shocks. i am going to ask a mechanic who is my next door neighbor to change my shocks. i want to buy the shocks myself.
i have research online, there are
1. oem kyb w0133-10808712 from partsgeek
2. kyb 343442 from partsgeek
3. gabriel strut jcw-gabg51783 from jcwhitney ( half price of oem )
the gabriel does call their part shock, they call their part strut, and i check gabriel website, it fit my car. but i do not know if the replacement work will be a lot more than the part call shock.
usually the shocks has only 2 nuts and bolts holding the top and the bottom. very easy to change it if they are mechanically inclined. i do not know if this is true to my case.
anyone has knowledge and input?
susucosp is offline   Reply With Quote
Old 10-04-2013, 03:05 PM   #2
Since you've not provided a link, I don't know exactly what you are looking at. A strut is the shock assembly used in the front and has spring perch and linkage mounting points incorporated into it. A shock for the rear is simply the piston.
Yes top and bottom bolt/nuts only. Access to top nut is through two small access panel covers in the hatch. Dead simple job to replace rear shocks on the LB. Sedan owners wish they had it this simple.
Old 10-04-2013, 06:22 PM   #3
susucosp
here are the links, i want to know which one is best choice
Wink 3 rear shocks fit my 2008 yaris 3 door automatic
2008 yaris 3 door hatchback automatic need rear shocks, these are the 3 shocks i find on the internet that may fit
since i do not know the forum rules so i do not post the links.
1. http://www.partsgeek.com/catalog/200...html?brand=kyb
2. http://www.partsgeek.com/ss/?i=1&ssq...43442&x=14&y=4
3. http://gabriel.com/product-search/li...partnum=G51783
which one is the best choice
Old 10-04-2013, 03:20 PM   #4
The Yaris has shocks in the rear, not struts.
I sell the KYB shocks and also can sell Tokico rears. Support our community by letting us earn your business.
Old 10-04-2013, 06:20 PM   #5
susucosp
Any rear shocks out there interchangeable with Yaris? DeathBeard Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 07-04-2013 03:58 PM
