Old 10-14-2013, 05:18 PM   #1
Lerico
Drives: Yaris 2012
Max Wheel Width on Factory 175/65R15 Tire?
Hi, what is the maximum wheel width I can safely use to mount the factory 175/65R15 tire?
Is 15x6.5 too wide?
Lerico is offline   Reply With Quote
Old 10-14-2013, 05:24 PM   #2
You would have to check the specs for the actual tires, but typically 175s are rated by the tire manufacturers for 4.5" to 6" rims.
Old 10-16-2013, 03:14 AM   #3
BLOODY_STONE
Drives: 2009 toyota yaris 1.3 sedan
get a wider wheel and a wider 185/60 15 tire .. yaris comes in stock with this size so there would be no worries for you
BLOODY_STONE is offline   Reply With Quote
Old 10-17-2013, 02:52 PM   #4
Lerico
Drives: Yaris 2012
My 2013 LE from Canada comes with 175/65 15 tires on steel wheels.
Well, my winter tires are 185/60 15, so maybe I will put the alloys in the winter tires then. Kinda stupid, but looks like that's the only way to go unless I go find some OEM toyota 15x6 alloys.
Old 10-17-2013, 05:18 PM   #5
BLOODY_STONE
yup .. toyota alloys are kinda hard to find for me too ...
Old 10-18-2013, 11:08 AM   #6
You can easily run 175's on a 6.5" wheel width. It will stretch a little, but it will work just fine.
Old 10-18-2013, 02:02 PM   #7
kimona
kimona's Avatar
Drives: 2014 White VITZ
^this^
Old 10-18-2013, 11:19 AM   #8
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
I am running 205/40 on 10" wide wheels so if we assume your brand tire stretches as well as mine, then we could assume via a proportion that a 216.829mm wide wheel would fit which converts to 8.537" wide. So 6.5" should fit in there no problem.
Factory Wheel & Hubcaps fazali Items for Sale by private party 3 03-06-2007 10:52 PM
Wheel Width tiksman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 23 11-22-2006 11:25 PM
Factory Lowering Springs + MAX Wheels? What are the options? bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 05-24-2006 08:10 PM
