![]() Drives: 2011 Yaris 3-door Lift-back Join Date: Feb 2013
Toyota Care over - Now what?
I almost at 30k miles in my '11 Yaris and I had my last free servicing at 25k.
Should I buy a maintenance plan from my dealer? Extend Toyota Care? Go to a private mechanic? This is my first car so I'm not sure how strictly the factory maintenance manual needs to be adhered to? And if going to a private mechanic vs. a dealer for servicing makes a big difference to resale? Any thoughts or suggestions on this (common) issue? PS. I searched hard for relevant threads (thinking this would be a common problem) but I didn't find any that answered my question. |
![]() ![]() ![]() Drives: '10 Yaris LB Polar White Join Date: Oct 2010
I'm in the same boat, today I completed 30k oil change without all the extra expenses. After buying oil change plus OEM air and cabin filters. It cost me 90 bucks. I won't do that again. I knew very reliable shop/mechanic owner here, I will just go back to him. After all those free oil changes under Toyota Care I feel like I'm on crack, needing a fix of free oil changes.
Just follow your manual for the next 35k service. Do most of the PM's yourself and find a good mechanic. Toyota dealer service will always be there anyway. |
#3 | |
![]() ![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: Sep 2012
#4 | |
Sorry, man I can't. I live in a Condo Complex, very strict rules not working on cars on the property. |
Change your own oil twice a year. Mines never been to the dealer for anything but the leaking water pump and the leaking oil pressure switch. WP under warranty OPS cost me $40.
2009 ~35k miles Wifes Camry never been there either 108k miles new in 2004.
![]() ![]() ![]() Drives: 07 Yaris Sedan, Auto Join Date: Jun 2010
just change synthetic oil every 10k miles are you're all good.
![]() ![]() ![]() ![]() Drives: 2017 Yaris IA, Pulse Red, Auto Join Date: Jun 2010
The only thing you have to do for awhile is oil changes. The first time after ToyotaCare I took mine to a TiresPlus store - had a coupon for a synthetic oil change and even though I had an appointment, I was there 3 hours because people buying tires kept cutting in front of me. And it cost $74. Plus they spilled oil all over that black plastic thing.
Last month it was time for another oil change, my dealer sends me coupons and it just happened to be one for an oil change. Done at Toyota this time, it cost only $48. Totally worth it to me because I am not in the mood for doing my own oil changes. Plus they have good espresso at the dealer (free). |
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
Warranty is over? Time to boost it :)
I've done my own maintenance on mine. I've not had to do anything to it other than change the oil. The Yaris is the easiest vehicle to change the oil in that I've ever worked on.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
Mr. 155 and climbing
you will hear both sides of the coin.
some will say to only worry about oil and checking your tires. others will say to pull out your maintenance manual and make sure that you not only adhere to, but log the maintenance done at the intervals they tell you to ensure that the various warranties are honored. I say find yourself a reputable third party shop and stick with them. If you want to learn how to do your own oil changes then great, but if not just don't take it to Walmart or some speed lube shop unless you have it on EXCELLENT word they have good practices...for example they do not torque your lug nuts with air tools, or they shouldn't be using an air tool for the drain plug on the oil pan. Over torquing can cause warping and such which in turn causes possibly big troubles down the road. Just take some time and read up in the Maintenance portion of the forum and read it knowing that you might wanna follow up to be sure someone knows what they are talking about. Not sure if this helps, but its what I got right off hand.
Transmission fluid (M/T and A/T) is generally recommended to be changed every 30k. And aside from that, you'll really only need to do oil changes (with oil filter) and air filter changes. Also, if you have a cabin/pollen filter, check and change that as needed. If you do all this yourself, you'll save a ton of money. Inspect your spark plugs around 50k-60k (should take em out anyway so that you can put new anti-seize on them). Replace if need be.
I'm sorry to hear that :-/ No garage huh? Well if you'd like, I can make a video of changing the air filter/cabin air filter to save you some $$$. It literally takes five minutes for both =].
#12 | |
Hmmm the consensus seems to be to do oil and filter changes myself.
What about the 25 pt. checks and tire rotations, etc.? |
#14 | |
At the moment, that is all that comes to mind. I am more than positive others will chime in about what to check, but you are the driver. Any noticeable noises or awkwardness with the car should be addressed. |
#15 |
I'm the thriftiest person I know, but I still don't change my own oil. I found a place that is not quite 10 miles from my house and charges an even $20.00 for an oil and filter change (total cost, including tax, etc).
#16 |
![]() Drives: 09 yaris blazin blue Join Date: Apr 2012
so stupid question....how to a make my own thread? lol
#17 |
The serpentine belt on my wifes Camry is 9 years old with 108k miles and is fine!
#18 |
| Is 'Toyota Care' for real? | HYang | General Yaris / Vitz Discussion | 21 | 03-25-2011 09:51 PM |
| Forbes' 'Worts Made Cars on the Road' List Doesn't Include Toyota | MadMax | Off-topic / Other Cars / Everything else Discussions | 3 | 04-11-2010 11:34 PM |
| 2011 Toyota Yaris Hybrid | tuckevalastin | General Yaris / Vitz Discussion | 48 | 03-30-2009 07:42 AM |
