![]() ![]() Drives: 2010 3dr hatchback auto red Join Date: Jun 2010
engine air filter
I read the post on cleaning the MAF sensor & bought that spray. When I bought it I thought about buying a new air filter as that's never been replaced. My manual does not give a part number, location, directions for replacement or any info regarding the air filter. I searched our forums & could not find anything here. Can anyone help?
The filter housing is located right in front of the battery. There are two metal clips that you flip down to and then the other side of the cover is seated into a groove. Once you lift the cover the filter is right there. There is a square corner on the filter, note where that was positioned and orient the new one the same way.
As for part numbers, you can always check the book by the filters in the auto parts or big box store, but off the top of my head the Fram part is CA10190.
| Unique Smell from Air Going Through AC Blower | EddieCabael | DIY / Maintenance / Service | 30 | 01-19-2015 09:08 PM |
| DIY - Cabin air filter location (Belta, Vios, Yaris sedan) | Murtaza_murti | DIY / Maintenance / Service | 5 | 04-05-2012 11:03 AM |
| Correct air filter not fitting right in sedan? | JerseyJeff84 | DIY / Maintenance / Service | 13 | 09-28-2011 02:27 PM |
| Engine Air Filter | Shadowbeast | DIY / Maintenance / Service | 7 | 06-16-2010 09:00 PM |
