Old 01-20-2014, 04:01 PM   #1
UnseenK
Drives: Yaris '09 White Sedan
Battery discharge?
http://i.imgur.com/CmXohWV.jpg
http://i.imgur.com/teZMkbU.jpg
Click me!
Any idea why that could be happening, and what I need to do to solve it?
UnseenK is offline   Reply With Quote
Old 01-20-2014, 04:13 PM   #2
That is corrosion. It typically occurs because of acid leakage from battery. Use a battery terminal cleaning tool (which is a set of male and female brushes to clean the battery post and the terminal) or sandpaper. A mix of baking soda and water rubbed on there during the cleaning will also neutralize any residual acid.
Old 01-20-2014, 04:39 PM   #3
UnseenK
It seems like every battery I get this happens to, it never happens to the other 3 cars at my house. Is this just a common issue with our cars, or just a common issue with mine? I live in a hot climate as well, not sure if that plays into it at all.
Old 01-20-2014, 04:56 PM   #4
I haven't seen corrosion on any of my Yaris. It may be the fact that you are purchasing non-sealed liquid electrolyte batteries, which are more prone to boiling over in hot climates. It also may not be a bad idea to have your alternator tested to verify that its internal voltage regulator is working properly. If it is putting out too high of a voltage (over 14.1 volts) it may be causing the batteries to boil over as well.
Old 01-20-2014, 04:50 PM   #5
alanwagen
battery washer
Clean your terminals as mentioned before and then install these. They should help. http://www.amazon.com/989-Anti-Corro.../dp/B000CQFS0O
You can get them at any auto supply including Wal-Mart. You can also get dielectric grease also which helps also. I use this on bulbs so they don't lockup due to corrosion. good luck.
http://www.amazon.com/Permatex-22058...lectric+grease
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
Battery keeps going dead Outdoorsman In Car Entertainment + Electronics (audio / video / alarm) 6 09-09-2013 04:43 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
Battery discharge omega3126 DIY / Maintenance / Service 0 05-19-2010 12:00 PM
